320i radiator upgrade - doesn't fit - need help
sonoma
just bought a 320i radiator off of a fellow FAQ'er, then bought the lower hose from Bav Auto (from their 320i rad kit) , after pulling the old one, I slid in the 320i one, and the fan is very close to it and it hit the radiator at the bottom where the metal is crimped to the plastic part, then the lower hose seems too long,
has anyone else ran into this? any ideas?
can i get a shallower fan?
thx
Dave in MA
'75 Golf 2002
1. you need a new fan anyway - yours be chewed by plastic
eating rats
2. you need new motor and trans mounts to hold
the motor back - and possibly the right motor mount limiting
stop bracket to prevent motor dive during sudden load/braking
this wont do at all :
'64 R27 250cc #383851 18,000m
thx
There's very little room there either way... many guys like myself switch to electric pusher fans in front of the radiator (Yep, let's add more hassle and planning to this supposedly bolt-in swap).
Also, the bottom radiator hose needs a section cut out of the middle, and a piece of pipe of some sort to make a union... not quite a bolt-in, huh?
Bring a Welder
definitely ditch that fan. either get a new one or preferably switch to electric in front of rad.
that old one you have will throw a blade chunk at some point and trash your new rad. btdt.
and I echo the check your motor and trans mounts comments.
2xM3
And don't just check the motor and tranny mount for the radiators sake. If those mounts are worn out then you are also causing misalignment in the drive shaft which means destroying guibos. That fan is a symtom of another issue, replacing it with an electric fan may cure the fan in radiator issue but won't cure the actual problem
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
look at the right(passenger side)motor mount.
You should see a bracket that bends up at the front to limit
the travel of the right mount rubber during high loading.
You should be able to have the red plastic fan blade (you do need a new one because you have many chunks missing) install with the 320 radiator
