Rear Swaybar
smhheidari
Stock rear is 16 mm. I would suggest you leave it in place. It helps reduce body roll when you turn the car. Without it, your car will tend to be sloppy in the rear. Sloppy rear doesn't sound good in any context.
williamggruff
I removed my rear sway bar long ago, just to reduce wheelspin in corners at autocross (combined with E21LSD/Bilstein Sports/H&Rs/Polys/big front sway, etc.). Probably not an ideal setup for some, but it works for me. I don't seem to notice any penalties on the street.
Bring a Welder
Nothing worse than understeer will happen-
when you reduce the rear roll stiffness,
you reduce the total amount of front grip relative to the rear.
Not a big deal. And semi- standard testing procedure...
