Brake Fluid Recommendations
DakarDoug
Castrol GT LMA, DOT 4 for the street
not silicone, not DOT 3...
Basically any DOT 4 real brake fluid will do.
HTH
Tom Jones
Is it preference or is there a reason some use Castrol over ATE over Ford over any other brand?
Just curious as I will be heading in this direction soon, with my looooong term project.
Thanks
Chris C.
I think it's preference. ATE blue and gold are also a good choice,
because then when you do a flush, you can see that you've
gotten a complete flush.
I use the LMA in everything, and just never have problems.
But the Ford stuff is great, too- I tried it when I thought I had
fluid temperature problems.
I actually like the pedal feel of the LMA.
Agreed that Dot 5 (silicone) didn't work for me. Squigggy feeling,
never really got a good bleed- on an all- new system.
Changing it annually is the big deal in my book.
I've always used Dot 3, usually Prestone, for the 40 years I've been driving 2002s - never a problem. The more important thing is to replace it annually.
didn't mean to hijack your thread, but like I said your post is timely.
I agree big time about changing brake fluid yearly, but bleeding the brakes is not a favorite of mine. Thats why I've been looking into brake bleeders.
Does anyone use a brake bleeder using compressed air?
Does anyone use the brake bleeders you pump up?
I have been looking at them the last few days and wonder if the hand pump ones are any good? I have an air compressor and was going to find one that worked off that.
Again, sorry Doug for the hijack. Feel free to hijack any one of my posts, lol.
Chris C.
I use the bleeder where you pump the container and it pushes fluid through. I got from Bavauto and I love it. You add a quart of fluid in the reservoir, screw the cap on, pump it to about 15 psi and go around the car's bleeder screws. I usuall atyach a piece of clear hose to the nipple, open it, watch the fluid go through to a glass jar and then close.
The same cap works on all bimmers, and I use LMA on all of them.
ATE may have a slightly higher boiling point and the dye is a neat feature but I don't like the brake feel and the price is significantly more. (like 6 times) And considering how much brake fluid I go through, ATE is not justified for my needs.
Pierre
O==00==O
69 2002 (M20), 74 tii, 76 533i, 79 323i, 80 732i, 84 323i (S50) 91 318is, 96 318ti (S52), 97 Z3, 02 330i, 03 525iT, 02 R1150 RTP.
Auxiliary Lamp Brackets  Kamei Reproduction Front Air Dam
I have the Motive Black Label pressure bleeder and its great. Its nice cause if you have a leak somewhere it'll help you find it in a hurry. It makes bleeding the brakes pretty painless and you don't need to bug your wife/child/friend to help you.
