Alternator Stud & Bushing goo too!
MrSharky
Okay.. got the alternator off, and turns out there's a boatload of goo where the new bushings should go...any tips on cleaning it out?
Also - see attached pic - the stud that comes out of the engine appears to be chewed up pretty bad. Is that a replaceable part? Doesn't show up on any of the realoem diagrams that I could find... wonder if there's any chance anyone knows how or where to get a replacement??
thanks in advance,
Matt
I needed a car, and a hobby....
Nor'East '02ers-
www.bmw2002.us
Betty VIN 4229155
The original colour was Malaga, paint code 021
In this diagram, I believe the part I'm looking for goes thru 16, 17, 15 and is capped off by 7.
Nor'East '02ers-
www.bmw2002.us
Betty VIN 4229155
Hey Matt,
Just pulled out my alternator last weekend and had the same issue. Contact Steve @ Blunt. His email is Steve@Blunttech.com
You can get new bushings for very cheap, also make sure to get new pressure rings. The new bushings can be difficult to get in so take your time and use clamps if you have them.
Use carb cleaner and a pie pan with gloves to clean this. Use a razor blade and a wire brush. Clean everything really well to insure the new bushings fit.
Dave
1972 Malaga 2002
engine block bits as it screws into the engine block. You probably should replace it, but just don't break the old one off removing it!
I'd recommend urethane bushings for the alternator vs the OEM rubber ones. Rubber bushings will last 2-3 years and turn into black goo (what you're cleaning off). Urethane bushings will last...well, indefinintely.
And make sure you get a urethane bushing for the lower adjustment arm too...I think there's a bushing for a VW Rabbit that works. Someone will know the application.
cheers
cheers
Mike -
Would you mind posting the diagram?? I'm still having trouble finding it - Blunt was looking too and had trouble finding it.
Thanks!
Matt
Nor'East '02ers-
www.bmw2002.us
Betty VIN 4229155
There is in fact a bushing Mike refers to from a VW that is urethane. I bought mine from Hueberger VW when I was stationed in Colorado Springs years ago....they do last, still running it. I think the info/PN is listed in the compliation of info called "Tech Tips" in a black binder that was published by BMW CCA, also years ago. I will look in mine this evening to see if I can dig it out.
Snakedriver
74 02Lux
02 M Roadster
72 Volvo 1800ES
74 02Lux
15 M235i
72 Volvo 1800ES
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf." -- George Orwell
for that Alternator Stud and coulnd't find it either. It screws into the lower timing chain cover and isn't on the page with the cover. Best thing to try is to remove the one you have and take it down to a NAPA store or the like and match it up. It's nothing special, just an (I think) 8 mm stud.
cheers
Thanks Mike - it's definitely not on any of the OEM diagrams that I've been able to find... think I even stumped Blunt (do I get a prize for that ?)
But.. after some digging and looking - I took the old one off (came of much easier than I expected it would) and you're right - it's an 8mm. For some reason, none of the auto parts stores around here have these things. I checked Home Depot too, and the best I could find was a metric bolt. I cut it down to size, and I think it'll work at least temporarily. How does one ask a Home Depot guy for an 8mm stud??
Oh, and after poring over the OEM site diagrams, I did come across this...
07 12 9 908 135 07 Stud bolt M8X50 1 03/1966 07/1977
I'm pretty sure it's right - 8mm x 50 mm (which is pretty close to what I took out of there - it was bent so I'm not positive of the length, but it was closer to 5cm than anything else)
Anyway.. now I'm having trouble finding the bushings for the slide rail....they're around, but backordered. I guess I'll just have to be patient.
Nor'East '02ers-
www.bmw2002.us
Betty VIN 4229155
Just a little off topic...
Do the bushings for the alternator really need to be made of rubber/urethane? I would like to replace mine and I can machine a set in either aluminum or steel.
I don't like the "slop" that the rubber mounts have in them and I think (in theory) sturdier mounts would be better.
Fishhead
Motorcycle Big Brake systems
Be yourself and be free with your thoughts because those who matter don't mind and those who mind don't matter..
I ain't no rocket scientist, but I think if you made them out of some sort of metal, you wouldn't have enough "give" - too many metal parts clanking around in there together.... I think the ears of the alternator might be at risk of cracking... again.. that's just one man's opinion.
Nor'East '02ers-
www.bmw2002.us
Betty VIN 4229155
Oh.. and I forgot to ask... does that look like the pieces are in the right order of assembly? I didn't take my "before" pictures....
Nor'East '02ers-
www.bmw2002.us
Betty VIN 4229155
I am confused. Are there really urethane bushings for the mounting of the adjustment bracket to the block (or was this referral to the mounts on alternator itself--I have never seen any for the bracket)?
Yes, the urethane bushings last MUCH longer, and the sequence in the photo is correct for reinstallation (circlips to front).
Lubricate the bushings (I use silicone grease) liberally before insertion and make sure everything is aligned before exerting real pressure. You will need to use a clamp or vise to fully compress the bushings so the groove for the circlip will be exposed (I used a 15mm or so socket with the washer).
Not sure if they're urethane, but there are bushings for the bracket:
11 72 1 261 404 is the part number... go to bavauto and search "alternator" and you'll see the picture.
Thanks for the grease idea...wish I'd done that beforehand... that was a beyotch to get those bushings in with just my hands. ;)
Nor'East '02ers-
www.bmw2002.us
Betty VIN 4229155
