Drain & Fill Plugs
davidmcw
Just got '02. Drain plug on transmission can be removed. Fill plug is frozen. Has any one used speedo connection to fill transmission?
Previously: 1940 BMW 327, 1951 MGTD, 1965 MGB,1967 BMW 1602, 1969 Lotus Elan, 1970 BMW 2002,
1972 BMW 2002tii, 1973 Porsche 914, 1983 MB 240D, 1987 MB 300D, 1987 VW GTI, 1997 MB E320, 1992 & 1999 Miata
Currently: 1976 2002, 1993 MB 300TE, 2004 MB E320
The guy that did mine said you need to use a hammer and smack it a few times. i could not budge mine, he tapped it medium hard with a hammer and it came right out. It is a tapered bolt
I'm not as dumb as I look
74 Verona
06 Audi A3
09 Mercedes C300
06 VW Passat
03 VW Conv Beetle
You might start with really light taps.... Would hate to see you post about how you fix the threads on the fill bung or worse how to repair the hole you punched in the side! Just thinking worst case...no really,spray it, tap it,try and turn it. Rinse and repeat.
'76 2002 anthrazitgrau 'Eli' the Chancellor
'87 325i delphin 'Chandler'
Can't fill via speedo- wrong angle, and too low! Also, you'd have
to remove the drive gear...
Get a longer wrench- the fill can be REALLY wedged in there....
Worst case, cut a small hole in the tunnel above the vent hole, pull
the vent plug out, and fill it that way. Then add the remote vent
to it up in the engine compartment, and in future you could fill it that way!
shoot, I should do the race car that way...
heh
Sounds like an excellent plan if all else fails! Thanks, Toby!
I've tried the hammer routine to no avail. Wanted some other option before moving to a larger hammer! Did not want this to turn into a nightmare.
1. Soak the plug threads with a quality rust penetrant like Rost Off or PB Blaster.
2. Use a propane or MAP torch to warm up the plug. Don't get it red hot! Just warm it up.
3. Use a long handled wrench; add an extender if you can.
4. Repeat as needed.
Heat and rust penetrant will work if used with patience. Have a fire extinguisher handy! The smoke wrench can be unforgiving.
Good luck...ned.
'74 tii rolling resto
I Used a 17mm allen with a 17mm boxend on it and a put a pipe on the box end. Came right off. Leverage is your best friend!
-Nathan
  • 2 years later...
  • 7 years later...
I'm in a dilemma for which I hope to get some direction.
I was going to replace the differential oil on our '75 and took the advise of others to loosen the fill plug BEFORE draining the diff.
Here is what I encountered:
It appears that a previous owner swapped out a skidded-up drain plug with the fill plug.  Plus, there appears to be some kind of foil gasket.
It feels like the hex socket is partially stripped, because 10mm hex has a loose fit about halfway into the socket but won't bottom out, however a 3/8" hex bottoms out and fits more tightly in the bottom of the socket.  I'm wondering if a PO crammed an SAE plug in there and used a home-made gasket to prevent leaking.
Anyway, I couldn't get it to budge with a 3/8" drive hex on a 15" breaker bar (pushing counterclockwise/upward from underneath the car isn't very efficient), so I tried to use the chisel method.  All I did was turn up a couple of nice chip curls on the face of the plug:
The second photo shows how the outside half of the hex socket is bunged up.
Unless someone here has better advise, I'm going to use a hex driver on an impact wrench, and if I completely round out the inside of the plug, then I'll use one of these:
Edited by Clevis Woodruff
Double entry of same photo
