Schnitzer 2002ti (Ernst Furtmayr)
The 4th picture down of cylinder head combustion chambers is the best example of a 2002 i've seen. Not that i'm any expert but i've seen inside a lot of fast 2 valve ohc motors and they all have the same features. Bathtub to unshroud the valves, angled squish at the side. Piston would have about .03" squish band at the outer edge, .05" inner edge, valve pockets cut for clearance. radius dome cut gradually bigger till compression ratio is right. Wish I could see it with the valves out.
Many thanks for the blog. Wish I lived closer so I could lend a hand.
