I can't turn right when it is cold...
Okay..72 2002. when it is cold outside (under 30 degrees farenheit) and I turn my right turn signal on, it flashes momentarily and then doesn't work. Left turn signal works fine. If I jiggle it a little, sometimes it will work. Do I need to replace the switch, or can I fix.
Please help...I need to turn right eventually.
By the way, this is not intended as a political statement..
Lets see, first check all your connections. I forget what was doing this to seths car, but i think it had something to do with the connection to the hazard switch or something. Its a good idea to just clean all your fuses/holders, as well as all the bulbs/sockets. Unplugging and plugging back in various things can also break the crusty shit free and give you some more good amps-transfer... HTH!
-Rob
1. Check ground, especially on front turn signal
2. Pull steering wheel and column surround, check turn signal lever for excessive play and old grease. You said it works sometimes if you wiggle it. Sometimes cleaning out the 30 year old grease and putting in a small amount of fresh grease will cure the problem. 3. Are you sure the stalk is actually turning all the way on? When they wear badly, the stalk (lever) may not be able to make contact because it's not traveling as far as it should. If there's a lot of wear, you may be able to peen the pivot point to take up some of the wear. You'll have to remove the switch to do this.
4. If all else fails, try another switch while you have the thing all apart so you won't have to do it twice.
Good luck
Mike
Nevada '69
Sahara '73
