Quantcast
rear gas vapor tank & Emission delete
  • Please log in to reply
9 replies to this topic
#1 c.d.iesel
c.d.iesel
Posted 22 November 2007 - 03:55 AM
....here are the tank venting bits you can install when you remove the gas
tank venting system that is routed to the vapor tank in the trunk,
the hoses to the front of the car, the charoal canister
in the front... just order from Bill Williams
@ MAXIMILLIAN -
Posted Image
PART ID IN DIAGRAM. ...SIZE OR QTY. ...PRICE in Euro ...BMW PART #
#03 Rubber grommet 16 0,001 1,33 €
16 12 4 584 137
#04 Fuel hose 6X11MM X 0,122 6,10 €
13 31 1 272 750
#04 Fuel hose 8X13MM X 0,143 10,20 €
16 12 1 180 409
#05 Sleeve X 0,001 1,03 €
62 16 1 350 285
#07 Vent pipe 1 from 1971/03 to 1977/07 0,024 17,00 €
16 12 1 113 338
#09 Grommet 1 0,005 0,71 €
16 12 1 101 014
Remove this stuff and toss it in your sisters trunk
Posted Image
'64 R27 250cc #383851 18,000m
#2 JayKray
JayKray
Posted 22 November 2007 - 06:29 AM
I need to do this....
Where does #9 end up venting to? another hole in the bottom of the trunk?
thanks CD
#3 LDubber
LDubber
Posted 22 November 2007 - 06:40 AM
which one is the tube that runs under the driver side frame rail ?
Does there need to be a vapor tank ?
is there any return fuel off the carb ?
#4 PatAllen
PatAllen
  • LocationQuebec, CANADA
Posted 22 November 2007 - 06:47 AM
funny, that "euro" vent pipe is still available while the "us" one that feed to the vapor tank is NA...
I need the NA pipe...if anyone of you does the conversion, plz send me your tosed stuff !!
thanks.
2006 530xi, 1974 2002 Automatic summer DD, 1999 323i
1985 XR4TI, 22psi ±300hp
1986 yota pick-up
#5 BillWilliams
BillWilliams
Posted 22 November 2007 - 07:45 AM
Posted Image
Posted Image
Posted Image
The fuel pipe ifrom BMW is now plastic, not metal. I still need to dress things up a bit.
1972 2000tii Touring #3422489
FAQ member #5
#6 ingraham
ingraham
Posted 22 November 2007 - 03:08 PM
there is no performance advantage in removing the vapor recovery system, and it keeps a bunch of hydrocarbons out of the air you breath.
Curt Ingraham
1972 2002tii, 1976 2002
Improved 2002 Radiators
#7 c.d.iesel
c.d.iesel
Posted 23 November 2007 - 04:59 AM
.....ahhh but GLOBAL WARMING feels soo nice !
#8 mike
  • LocationBeavercreek OH
Posted 23 November 2007 - 05:44 AM
That you plug the vapor recovery return line at the gas tank--otherwise it will siphon gas out when the tank is full. Do this, of course after you connect the vent at the rubber filler elbow to its new vent line.
#9 02friend
02friend
Posted 28 November 2007 - 04:32 PM
..it keeps a bunch of hydrocarbons out of the air you breath.
Can I vent into the cabin instead? I think I'd like to increase my hydrocarbon intake...it counts as fiber in my diet right?
I have the stock system but would like to delete, many because of the twisted turn i have to make with the fuel line from the fuel pump to the fuel return valve then to the 32/36 weber..its icky looking, think pretzel.
The main reason i have not done this yet is because of the PITA of routing the tubing in a squarie (US).
I'd sacrifice surrounding air quality for cleaner fuel flow.
~1976 2002~
#10 PatAllen
PatAllen
Posted 28 November 2007 - 04:37 PM
thanks.
i was serous, if you remove that stuff, i need the white plastic pipe that runs from the filler neck thru the expansion tank...
1986 yota pick-up
