Outside Dimension of 318/320 Return tube coolant
xferboy
Go to solution Solved by nbcbird,
Evening.  Does anyone know the size of the coolant return tube on a 318 M10?  Is it the same size on both ends (appears to)?
I spent a 1/2 hour on the parts sites, but none of the hoses list their size.
I was supposed to get one with a package, but it didn't come with it, so if it was a standard-ish size, I'd try making one.
Thanks for any info
Allan
pn 11531264718
http://www.wallothnesch.com/ruecklaufleitung-320i-ab-7-76-11-11-13.html
I will be, I'm wondering the size, so when I'm wandering through hardware stores, I keep an eye out for the correct size.
Is it the same size as the outlet on the back of an M10?
Thanks
Allan
Edited by xferboy
Nope.  I have done so for various coolant bodges of my own, and copper works fine.  Do flare the ends somehow.  I solder a bead all the way around the end,
that seems to work.
One of these years, I'll make a small- tube flaring tool.
not this year.
could the hose be one piece from the water pump to the heater,,
The pump nozzle is larger than the heater nozzle. A single piece of hose without an increaser won't work.
