Spitting, Sputtering And Low On Power
darrinos
Car ran really well previously but suddenly it doesn't want to run much at all, and will not idle or keep running in mid range. Backfiring on deceleration. Weber 32/36. Any clues? New fuel pump recently. carb is 1yr old.
Based just on the limited information in you post I would suggest you inadvertently bumped the distributor, affecting the ignition timing.  A vacuum leak is plausible, but it would likely cause an increase in engine speed rather than sputtering.  Crossed ignition leads, unrelated to any fuel pump replacement, is also symptomatic of sputtering and a definite power producing downer.  Fuel pump itself may be defective and/or you may have dislodged some gunk and forwarded it to the carburetor's idle jet.  Ohio Mike likes to keep those idle jets clean.  Gumout is not just for XMAS.
Retrace your steps.  Should be something obvious.
Thank for the tips guys. I apologize for the limited info. I was in a seminar and couldn't go into much detail. The car is a couple hundred miles from me and my son who's learning to work on cars (through the lovely little 2002) is having some problems with it. It's never done this before and kind of surprised me with it's recalcitrance. I'll have him try those things. I've had a terrible time with fuel pumps so that's why I mentioned that. While on the subject of fuel, where can a guy buy that rubber boot between the fender and the fuel tank? Mine is rotten and I worry that is sometimes a part of the reason I seem to have trouble with dirty fuel. (Small black pieces of something usually in the bowl.)
Thank you, gentlemen!
The 32/36 carb has two idle jets try unscrewing both of them and cleaning them with carb cleaner, if they are dirty your car won't idle and backfire.
HTH
71 BMW 2002 "Von Eiff" gone baby gone
73 BMW 2002 " Mingus "
04 BMW X5
75 Triumph Tr6
00 CLK 430 Conv
Honda Elite Scooter
Vespa Ciao
RealOEM.com will list most of your parts. If it has a price by it, it is usually available from BMW.
http://www.realoem.com/bmw/showparts.do?model=2213&mospid=47140&btnr=16_0384&hg=16&fg=05
I went through something similar on a 71 chevy truck. The symptoms were really weird. If the truck was in park it would run perfectly. In Park,  I could also rev it up as much as i wanted and it sounded great. No problems. BUT as soon as it was in gear and i attempted to hit the gas to drive it would sputter and pop and was completely undriveable. The most I could do was idle/drive it back to where i wanted to park.  I started with vacuum leaks, and fixed those. Next was re-tuning the Carb and checking fuel filters and pressure. I used a vacuum Gage to diagnose and fix everything i could find. Btw everyone should have a vacuum gage, its crazy how many problems can be diagnosed using one.   I was literally running out of options and the symptoms prevailed.  It just wouldnt run under load so to speak.
 Next  I was checking the spark plug wires.  I did this by misting the wires with water and then running a grounded screwdriver along the wires (but not touching them) with all the lights out looking for jumping sparks. There was some faint jumping so I replaced the wires.   Next was checking the spark at the end of each wire lead.  There was spark and almost every wire's spark was alternating between blue and yellowish  so there was a spark but I was expecting a strong blue spark each time.  In came a new coil and i went to check the spark again. This time it was still looking exactly the same as before BUT it was now making an very distinct "Snap-Snap-Snap" sound each time it fired.  It turns out that my coil was taking a crap. As soon as i replaced it all was great again.
As my late and much-missed father-in-law used to say, "Mike, 90% of your carburetor problems are in your ignition.  Keep your cotton-pickin' hands off the carburetor until you're sure everything in the ignition is up to snuff."  And he was almost always right.  He started mechanicking on Model T's back in the 20s.
That being said, those itty-bitty idle jets can get crud in 'em very easily, and since they feed gas up to about 2500 rpm (when the main jets take over), they can cause all sorts of running problems if dirty.
cheers
