Quantcast
76 M42.....turbo swap
  • Please log in to reply
37 replies to this topic
#1 jakeb
jakeb
Posted 18 August 2011 - 04:01 PM
Been underway for a little bit now just have some time to post some pictures. This is a car for Andy...super m42 swap
76 02..
BIG wilwood front brakes
VW rear discs
m42 swap/e30 5 speed
super 60 turbo
42lb injectors
stock motronic efi with a tuned chip
low boost around 7psi
The intake and valve cover will be powder coated red and charge pipes will be black. Waiting for parts to come back from the powder coater before I can put the rest together fire it up and get to tuning
Pictures are in no particular order
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
1985 e28 w/LS1/t56 and a bit more...
1970 2002 w/ m42 swap
-Contact me for m42 mounts or e28 ls1 mounts-
www.classicdaily.net
#2 mooseheadm5
mooseheadm5
Posted 18 August 2011 - 05:12 PM
Neat! Should roll out quite nicely.
#3 Mike_B
Mike_B Garage View Garage
Posted 18 August 2011 - 05:19 PM
Stock compression? I have the same turbo in my garage right now, and I'm interested to see the results.
#4 RIMSPOKE
RIMSPOKE
Posted 19 August 2011 - 12:32 PM
DO YOU THINK YOU WILL HAVE A PROBLEM WITH THE TURBOCHARGER
BANGING ON THE SIDE OF THE FENDER ?
#5 jakeb
jakeb
Posted 19 August 2011 - 01:12 PM
yes stock compression
There is space between the turbo and the fender and it will have poly motor mounts. If it hits I will make a little space with a slight hammer massage.
#6 AndyS
AndyS
Posted 25 August 2011 - 03:55 PM
Posted Image
Posted Image
Posted Image
This is the car and it will be sporting these Weds.
#7 jakeb
jakeb
Posted 27 August 2011 - 08:29 AM
Posted Image
#8 M5wanaB
M5wanaB
Posted 29 August 2011 - 07:08 PM
How are you going about tuning? Going to go Mega Squirt of RRAFPR?
#9 jakeb
jakeb
Posted 30 August 2011 - 07:05 AM
Tuning the stock motonic with tunerRT and an ostrich2. It will have a set of 42lb injectors and then a burned chip when it's all said and done.
#10 deutchfiend
deutchfiend
Posted 30 August 2011 - 11:50 PM
love the sequence pix. i cant imagine how much fun that is to smash in. how long did the build take you?
#11 Mfever
Mfever
Posted 31 August 2011 - 12:16 AM
where did you get the filter on the turbo? been looking for one of those.
BMW, its a way of life.
#12 jakeb
jakeb
Posted 31 August 2011 - 03:50 AM
Its not done yet....waiting on a oil feed line to the turbo then I can fire it up and get to tuning it.
The filter is from here
http://www.siliconeintakes.com/
#13 hendi72
hendi72
Posted 31 August 2011 - 01:14 PM
NICE! i just had to say.....nice work and on a very cool motor for our little 2002's!!! excellent, bra! keep up the photos and keep us informed! awesome!!!!
mark in miami
#14 M5wanaB
M5wanaB
Posted 31 August 2011 - 08:54 PM
Sounds like a good setup. You have a baseline tune to start with or are you going from scratch? I would think the AFM would be maxed out pretty quickly with that setup? any way around that?
#15 jakeb
jakeb
Posted 01 September 2011 - 05:58 PM
There is a guy in canada that I am working with that has a similar setup. He is running around 12-15psi in an e36 with a m42 and a blow through afm.
I am starting from scratch. Tune the idle with a wideband to set the new injectors....adjust all the maps to work with the new injectors. Then tune the WOT table under boost and transfer what I need there over to the PT tables. As well as pull a little timing in the areas where under boost/higher load.
#16 jakeb
jakeb
Posted 07 September 2011 - 02:13 PM
it runs!!
#17 AndyS
AndyS
Posted 07 September 2011 - 03:39 PM
Pretty cool!
#18 jakeb
jakeb
Posted 13 September 2011 - 04:45 PM
Exhaust is done....
Posted Image
Posted Image
Car is running and driving so now I will swap in the bigger injectors and start to tune it
#19 Ludvig02
Ludvig02
Posted 19 March 2012 - 05:42 PM
Where did you plug the oil feed lines into the motor?
Now that my M42 swap is done.... i still feel that need for a project. haha.
84 318i
86 325es
96 328is
89 325ix
74 2002
#20 jakeb
jakeb
Posted 24 March 2012 - 04:54 AM
There is a oil connection at the back of the head. m12x1.25 to AN3 fitting did the trick. need a manifold?
