M2 madness
M3M3
did you have them turned or replace them?  i measured the new, unused ones i got as spares...runout 0.004.  even new they appear to be out of spec.  interesting though...the wilwood spec for max allowable runout is .005-.008.  other places i have seen the max at .002.  i know i had huge brake vibration and when hand turning the rotor it definitely caught the brake pad a the high point.
Edited by mlytle
2xM3
got them back from being turned.  runout now .002.
the spares.  a slightly different design with directional cooling vanes.
got some new billy hd's in!
yeah, wrong number for an 02...they are for the 02 hauler..F250...working on that thing is nice.  do not even have to jack it up to change the shocks.
2xM3
that is what happens when a valve hits a piston, gets bent, hits the piston a bunch more, breaks off, rattles around destroying the plug, then knocks a hole in the piston top to let all the little metal bits drop into the crankcase.
clowns with sneakers?
"Clowns with sneakers" needs to be in your signature hahaha!
74 BMW 2002 Atlantik "Trinker"
I don't think I saw this specifically mentioned but was the change from the IE to SG radiators just for added cooling when tracking the car? I've got an s14 that runs hot in city conditions (mostly the temp starts rising when I'm at a stoplight), and I am trying to find a suitable option with SG no longer around. Do you recall which IE model you had been using and is it something you would recommend for a street application?
Edited by lyndsayh
'69 1600 Cabriolet
yes, change was for increased cooling on track.  i had the street IE rad.  it is basically the same size as an e21 rad.  IE also makes an alum race rad that might work better. challenge with an S14 is the thickness of rad and the clearance to the WP pulley if you have not moved the engine back.
I went with an custom SG rad because i wanted some particular dimensions.  mine is not a stock size (not even stock turbo size).  as shown in the pics, mine is also pushed forward and to the right as far as possible without it looking like i hacked up the top of the rad support.
it is made from the upper and lower tanks from two stock 2002 rads cut and welded together to make a wider one and fatter core.  any good radiator shop should be able to replicate.
also key is getting the electric fan right sized and as close to rad as possible without the blades deflecting into the rad.  this part is probably the most important for a street driven car.  no matter how big the rad is, the cooling is limited by the airflow through it.  more air=more cooling.
2xM3
If I recall, we did turn them.
And they warped again after.
:blink:
Ray
that's not what i wanted to hear!!  we shall see how mine wear....
big update for the car!!  usually i abstain from mods that provide only looks and not performance, but in the spirit of The Vintage, i made an exception to that rule.  i have had new roundels in a box for a year now, not wanting to disrupt the patina of the chipped and scared ones on the hood and trunk. i caved and put them on the car.....
tomorrow i will try to pretty up my back seat delete with the Esty carpet kit i have had for three years..... :P
Edited by mlytle
2xM3
I'm sure the new ones will be scared shortly!
:D
Ray
rear seat delete
Finally getting to this project..using esty kit.
Clear the space, including removing roll bar braces.
Cut off the old upper rear seat hangers
Use lower carpet piece to trace wooden bottom (7/16th ply)
Use upper carpet piece to trace piece of ensolite sound insulation
Cut piece
Peel and stick
3m super 90 spray glue on ensolite and back of carpet…stick!
More tomorrow on this project.
2xM3
sway bar modification
IE bar designed for connection to control arm.  the connection i am using to strut puts odd load on the end of the bar.  last one bent.  got new bar.  decided to strengthen the end.
hacked ends off broken bar to use for templates
cut up some spare flat steel to shape
here it the concept.  triangulating the bracket to the bar.
fun with welder
found rattle can of rustoleum blue in paint cabinet...close..
install tomorrow when paint dries....
2xM3
