rear gas vapor tank & Emission delete
c.d.iesel
....here are the tank venting bits you can install when you remove the gas
tank venting system that is routed to the vapor tank in the trunk,
the hoses to the front of the car, the charoal canister
in the front... just order from Bill Williams
@ MAXIMILLIAN -
PART ID IN DIAGRAM. ...SIZE OR QTY. ...PRICE in Euro ...BMW PART #
#03 Rubber grommet 16 0,001 1,33 €
16 12 4 584 137
#04 Fuel hose 6X11MM X 0,122 6,10 €
13 31 1 272 750
#04 Fuel hose 8X13MM X 0,143 10,20 €
16 12 1 180 409
#05 Sleeve X 0,001 1,03 €
62 16 1 350 285
#07 Vent pipe 1 from 1971/03 to 1977/07 0,024 17,00 €
16 12 1 113 338
#09 Grommet 1 0,005 0,71 €
16 12 1 101 014
Remove this stuff and toss it in your sisters trunk
funny, that "euro" vent pipe is still available while the "us" one that feed to the vapor tank is NA...
I need the NA pipe...if anyone of you does the conversion, plz send me your tosed stuff !!
thanks.
1985 XR4TI, 22psi ±300hp
That you plug the vapor recovery return line at the gas tank--otherwise it will siphon gas out when the tank is full. Do this, of course after you connect the vent at the rubber filler elbow to its new vent line.
..it keeps a bunch of hydrocarbons out of the air you breath.
Can I vent into the cabin instead? I think I'd like to increase my hydrocarbon intake...it counts as fiber in my diet right?
I have the stock system but would like to delete, many because of the twisted turn i have to make with the fuel line from the fuel pump to the fuel return valve then to the 32/36 weber..its icky looking, think pretzel.
The main reason i have not done this yet is because of the PITA of routing the tubing in a squarie (US).
I'd sacrifice surrounding air quality for cleaner fuel flow.
~1976 2002~
thanks.
i was serous, if you remove that stuff, i need the white plastic pipe that runs from the filler neck thru the expansion tank...
