Coil wiring problem.
ryanfudger
Getting the car back together after a four/five/six month hiatus. New motor is in, everything all buttoned-up. Never claimed to know what I was doing, but I obviously thought it'd be easy to hook up the coil when I pulled everything. But, after time passed, I've forgotten what goes where.
What I assume (but in no way am I saying is correct)...
Positive/15 side: red wire from pertronix and green/red wires from #87 start relay. I also have an electronic fuel pump that needs to be connected to the positive side (meaning all three terminals are now taken on the posi side)
Negative/1 side: black wire from pertronix and thin black wire from harness (I think it's a tach wire)
What I'm questioning...
The two wires coming from the wiring harness (Photo 2). One is brown/black (negative?) and the other appears to be some sort of pink/black (positive?).
The spliced-together black cables (Photo 3). I'm thinking they went to the points system, but I really can't even remember how points even worked, haha. Definitely not the only open-ended wire in this car (no smog + PO).
Ignorant question: if I wire this wrong and try to start the car, will I blow out my coil or pertronix?
Thanks!
  • 2 years later...
someone sent me this pic a short while ago when i was trying to get one of mine wired back up after a tear down....maybe it'll help
Just curious, but what is that box with 87, 86, 85 and 30? Where should I find that?
Thanks!
And Where is it located on the car? under dash, in engine bay??
Thanks for all of the help, this should get me going in no time!
Sterling
