Thread Topic: 1974 automatic 4280905. UNDER SURGERY Flat
Date: 5-19-08 06:59
Subject: Re: 1974 automatic 4280905. IT RUNS !!!
I spent two days working on the rust.
I fixed the front corners and the passenger side fender atachement.
I also started to fix the rear corner, around the fuel tank. That was the biggest job (minus the front clip) to fix.
Th big rough job is done, i have to grind down all the welds now, it look real bad but it is not that much...my white 02 was in more sad shape and that is 10 years ago already.
I also found someone deeply hiden un the frame rail...i named him Barney...this litle crapy mouse returned to dust, after spraying his pee all over in this car. When i weld i can smell it !!
bouhahhhaaaaaahaaaa....
I also burned one of my finger reeeeaaaal mad. It hurts.
1974 2002 auto
1997 Pathfinder
 Filesize:  285.13 KB
 Viewed:  9 Time(s)
 Filesize:  268.82 KB
 Viewed:  7 Time(s)
 Filesize:  366.67 KB
 Viewed:  8 Time(s)
 Filesize:  305.82 KB
 Viewed:  10 Time(s)
 Filesize:  339.43 KB
 Viewed:  6 Time(s)
            Re: 1974 automatic 4280905. Lets the fun begin. - PatAllen - 11-29-07 10:30
            Re: 1974 automatic 4280905. Lets the fun begin. - PatAllen - 11-20-07 07:45
             Re: 1974 automatic 4280905. Lets the fun begin. - PatAllen - 11-23-07 05:56
                   Re: 1974 automatic 4280905. Lets the fun begin. - PatAllen - 11-23-07 05:57
            Re: 1974 automatic 4280905. IT RUNS !!! - PatAllen - 2-8-08 01:20
                  Re: 1974 automatic 4280905. IT RUNS !!! - PatAllen - 3-5-08 06:51
                        Re: 1974 automatic 4280905. IT RUNS !!! - H_Krix - 3-5-08 09:22
                              Re: 1974 automatic 4280905. IT RUNS !!! - PatAllen - 3-5-08 09:30
       Re: 1974 automatic 4280905. IT RUNS !!! - PatAllen - 3-23-08 01:43
       Re: 1974 automatic 4280905. IT RUNS !!! - PatAllen - 4-17-08 05:10
             Re: 1974 automatic 4280905. IT RUNS !!! (nt) - PatAllen - 4-17-08 05:12
             Re: 1974 automatic 4280905. IT RUNS !!! (nt) - PatAllen - 5-17-08 07:05
       Re: 1974 automatic 4280905. IT RUNS !!! - PatAllen - 4-26-08 03:22
       Re: 1974 automatic 4280905. IT RUNS !!! - PatAllen - 5-17-08 07:04
       Re: 1974 automatic 4280905. IT RUNS !!! - PatAllen - 5-19-08 06:59
             Re: 1974 automatic 4280905. IT RUNS !!! (nt) - PatAllen - 5-19-08 07:02
            Re: 1974 automatic 4280905. UNDER SURGERY - H_Krix - 6-10-08 07:28
                  Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 6-10-08 09:44
                        Re: 1974 automatic 4280905. UNDER SURGERY - jakeb - 6-10-08 11:36
                              Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 6-10-08 01:18
                               Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 6-10-08 01:31
                   Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 10-25-08 01:02
                   Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 11-3-08 06:48
                         Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 11-3-08 06:54
                   Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 11-15-08 04:48
            Re: 1974 automatic 4280905. UNDER SURGERY - oz_tom - 6-30-08 08:21
                  Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 7-1-08 05:38
                         Re: 1974 automatic 4280905. UNDER SURGERY - H_Krix - 7-1-08 07:52
                              Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 7-1-08 08:42
            Re: 1974 automatic 4280905. UNDER SURGERY - esty - 7-25-08 09:36
       BUMPERS ON !! - PatAllen - 7-27-08 02:20
            Re: 1974 automatic 4280905. UNDER SURGERY - H_Krix - 9-29-08 08:35
            Re: 1974 automatic 4280905. UNDER SURGERY - PO - 9-30-08 05:50
                  Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 10-1-08 07:08
       Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 10-17-08 04:08
       Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 10-17-08 04:43
       Re: 1974 automatic 4280905. UNDER SURGERY - PatAllen - 10-18-08 08:41
