Thread Topic: '71 2002 M20 Conversion Flat
Date: 4-9-08 09:02
Subject: '71 2002 M20 Conversion
Okay, here it goes.... So, I've been reading this forum for 18 months now and purchased my first 2002 a year ago. After picking up the car (long distance purchase), the engine began to knock. It got so loud that I was only able to drive it for a couple miles. Long story short, the P.O. and I worked out a deal and I kept the non-running car.
The car has been sitting in storage while I tried to figure out what to do with the engine. At first, I looked into having a shop rebuild the engine but a stock rebuild seemed too expensive and used running engines were difficult to come by. I then started reading about the S14 and M20 swaps. The S14 intrigued me since Aardvark racing sells a step-by-step manual. Although the M20 swap was considerably cheaper, cutting up the transmission tunnel was not a job that I wanted to tackle.
However, after months of reading I decided on the M20 swap for several reasons (not to mention cost!). A local junk yard had just received a 1990 325i and I was able to source an e21 323i transmission from another member on the board. My next task was to contact Dan Williams for the engine mounts - SOLD (I bought the last set he had available at the time). Now I was fully committed to the conversion, only problem - I have never really worked on a car other than changing the oil, rotating the tires and wiring a stereo...
...until this last weekend. Got the car out of storage and it now sits in our garage. I started the dismantling process over the weekend and actually pulled the engine and transmission from the car last night! I'm sure I'll be posting more questions as I continue with this swap and will honestly try to document the process as I move along. Thanks to my buddy Tom A. who helped in the engine removal process & thanks to everyone who posts on this forum, it is an invaluable resource!
Cheers,
Chris
Arrival on flatbed
Front
Recovered Recaros
Engine Removal
[/img]
'71 2002 M20 Conversion - cjreents - 4-9-08 09:02
            Re: SeventyOne 2002 (M20 Conversion) - cjreents - 4-9-08 09:44
                  Re: SeventyOne 2002 (M20 Conversion) - 70roundtail02 - 4-9-08 11:46
                        Re: SeventyOne 2002 (M20 Conversion) - H_Krix - 4-10-08 07:43
      Re: SeventyOne 2002 (M20 Conversion) - mikekoch - 4-10-08 10:29
            Re: SeventyOne 2002 (M20 Conversion) - cjreents - 4-10-08 12:41
            Re: '71 2002 M20 Conversion - cjreents - 4-18-08 09:50
      Re: '71 2002 M20 Conversion - Dsigner - 4-22-08 05:56
            Re: '71 2002 M20 Conversion - BMPOWER - 4-28-08 08:14
                  Re: '71 2002 M20 Conversion - cjreents - 4-28-08 10:29
                        Re: '71 2002 M20 Conversion (Water Pump Theory) - cjreents - 4-29-08 04:19
                              Re: '71 2002 M20 Conversion (Water Pump Theory) - Orangecar - 4-30-08 09:45
                                    Re: '71 2002 M20 Conversion (Water Pump Theory) - cjreents - 5-1-08 12:40
                                    Re: '71 2002 M20 Conversion - cjreents - 5-1-08 12:43
                                          Re: '71 2002 M20 Conversion - cjreents - 5-26-08 09:09
                                                Re: '71 2002 M20 Conversion - 70roundtail02 - 5-27-08 07:15
                                                      Re: '71 2002 M20 Conversion (Sway Bar) - cjreents - 5-27-08 10:31
      Re: '71 2002 M20 Conversion - djm1968 - 6-2-08 01:38
            Re: '71 2002 M20 Conversion - cjreents - 6-2-08 08:42
                  Re: '71 2002 M20 Conversion (Transmission Mount) - cjreents - 6-29-08 09:16
                        Re: '71 2002 M20 Conversion (Radiator Mount & AFM Mount) - cjreents - 11-12-08 10:40
                              Re: '71 2002 M20 Conversion (Shortened Ebrake) - cjreents - 11-12-08 11:05
                                    Re: '71 2002 M20 Conversion (Shortened Ebrake) - Schweineback - 11-13-08 03:10
                                          Re: '71 2002 M20 Conversion (Shortened Ebrake) - cjreents - 11-13-08 07:56
