Thanks!
They're rabbit sport inserts in shortened strut housings, 275lb Eibach springs and coilover kits from speedwaymotors.com. Coilover kits required shortening and some back-cutting on the inside (lathe required) to accommodate the perches and glan nuts. The spacers are about 3" and are made of 1.5" OD .25" wall aluminum tube.
edit: I should also add that the kits, while designed for bilsteins, are not for *these* bilsteins. The hole in the upper perch was too small (or too big depending on how you look at it) for the strut to go through. I could grind off the lip the gaitors lock into, or increase the diameter of the hole in the upper perch. I opted to grind the strut, felt that the other way would weaken the perch.
Lots of work, but a good-looking result.
Mike
| 70roundtail02 wrote: |
| coils look really nice what setup/route did you go for them? |
