Date: 7-25-08 02:23
Subject: long call:pick-n-pull guys, need a E30 325e part...
To anyone who know a E30 325e car at a pick-n-pull, i need the tortional vibration damper that is mounted at the tail of the trany, right next to the guibo.
part #3 on the picture.
this is mostly found on late e30, there is two kind of this, the one from the 325e is a bit different.
So i realy need the one from the 325e. if you have the one from the 318 i may be interested as well.
thanks _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
51.58 KB |
21 Time(s) |
Date: 7-25-08 05:13
Subject: Re: long call:pick-n-pull guys, need a E30 325e part...
I've eliminated those on countless BMWs over the years. Just take the studs out and get 3 more bolts.
If ittt grunzz vit out itt, itt dooon'ttt neeed ittt. :) An old German mechanic I met one time said that... stuttering accent and all. _________________ Tom Jones
BMWCCA Life 49246
Vacaville CA
67 1600-2 Granada
+ 3 more 1600-2's
67 1800A stored
76 2002 F/S soon
86 528e 5sp Mine 369k
86 528eA Wife's
90 CRX HF 50mpg!
Date: 7-25-08 05:31
and the purpose of your intervention is ??
you want to tell me that you have one since you remove them all ? _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
Date: 7-25-08 06:02
Sorry, I only remove them from the car when they're bad. I wasn't meaning to be bad or anything...
I am planning on visiting a couple of PNPs tomorrow and will keep my eyes peeled for a good one. Are you looking for... #23 13 1 220 584 ?
that's the one that goes with guibo #26 11 7 511 454 Not the "normal" e30 guibo # 26 11 1 225 624 right?? The one that goes with the "624" guibo is #
the "454" guibo is used until production date 5/86 whereas the "624" is used after that date.
So, I'm going to look for a good "584" dampening ring.
HTH _________________ Tom Jones
BMWCCA Life 49246
Vacaville CA
67 1600-2 Granada
+ 3 more 1600-2's
67 1800A stored
76 2002 F/S soon
86 528eA Wife's
90 CRX HF 50mpg!
Date: 7-25-08 09:24
well, i am confused with the pn's. The one i need is the one that is not surrounding the guibo but is "outside" of it...otherwise send me the one you have, as it is for a project.
you can contact me off line plz.
Did you know that a 6 bolt guibo on a 5 speed od e21 is the same as a e30 and a e36 guibo ??
thanks very much !! _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
Date: 7-26-08 12:29
for the PN# check www.bmwfans.info
for the dampener itself check with the www.e30tech.com people ;) _________________ No expectations , No disappointment
Greetings
John
Date: 7-26-08 06:40
| instructorbill wrote: | | this one surrounds the guibo-- You still want it? |
yup, how much ?
i still need the one from a 325e too.
thanks !! _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
Date: 7-28-08 06:53
i sent you an e-mail instructorbill.
let me know.
Thanks. _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
Date: 7-28-08 06:54
| tjones02 wrote: | Sorry, I only remove them from the car when they're bad. I wasn't meaning to be bad or anything...
HTH |
Tjones, wathever you find let me know plz.
1974 2002 auto
1997 Pathfinder
