Let me start by acknowledging the great articles that are on TEP's web site. If you have an issue with your Weber carb, or if you simply want to learn more, go to this page:
http://www.racetep.com/webtechpage.html
Thanks to that site, plus a few articles here on 2002FAQ, I was able to sort out numerous problems that I inherritted from the previous owner. For instance, TEP's site pointed out that the distributor's vacuum line should NOT be connected to the intake manifold. Instead, when a Weber is bolted on, the vacuum should be connected to the Weber. Once I read the article, I completely understood the problems I was having.
After fixing numerous problems, the car was running good enough (if you use the term loosely) that I could actually start adjusting the fuel mix and timing. Well... that is... ummm... until the ignition switch quit working. Various articles and queries have been posted with the same problem; the key will turn to "Fahrt" but not to "Start"... apparently because of a feature that is supposed to keep you from accidentally engaging the starter again after the engine is running... which eventually breaks and keeps you from starting the car until it bloody well feels like complying.
So I sent an email to a member of our forum (who has "fixed" this on his) and started working on the windshield, which has been in dire need of a new gasket and lock strip.
Three things to note.
1) If you buy a 2002 that has an aged windshield gasket, from an owner was NOT a 2002 nut, then expect to have to remove gasket goop that has been squeezed into the cracks in a vain attempt to stem the tide.
2) If you order a windshield gasket and a rear window gasket at the same time, be sure to store them at opposite ends/sides of the shop, and do not pull them out of their respective bags at the same time.
*COUGH*
3) The $8
suction cup lifter from Harbor Freight is worth every penny if you are pulling a windshield. The only catch is that it is not designed to handle curved glass, so you need to use it in the center of the windshield.
And that is exactly what I did. I used a long utility knife to cut the old gasket while pulling it off the glass with the other hand. Then I pulled the windshield free with that big cheap suction gadget. Quick and easy.
I cleaned the crud off of the windshield, then started working on the car. Not only did I need to remove the aforementioned gasket goop, but I also had to clean up some rust that had formed under the old gasket.
At this point let me point out that, if you spread a bright fuzzy blanket on your hood to protect it, a high speed wire wheel will be attracted to it like a kitten to loose yarn... and it will become entangled just as quickly.
After that chaotic interruption, I finished cleaning up the rust with another one of my favorite cheap tools: a brass brush with a scraper that was marketed for cleaning charcoal and propane grills. It worked great!
I sprayed the metal with some inhibitor/sealant stuff, then fitted the gasket to the windshield while that dried. (If this was going to be a restoration, I would strip everything and do it "right"... but this car is beyond saving. I'm hoping that it will be something fun to drive while I restore the other 2002.)
The gasket went on easy enough, and then I sprayed some silicone into the groove where I would be putting the rope. I used the little red pipette that came on the carb cleaner, sticking one end in the groove and the other in the nozzle of the silicone spray. In the end, the pipette looks rather twisted after being run through all of the grooves, but it worked like a charm.
I asked a friend to come over to help, but I was able to put the windshield in place myself by using the suction cup device. He pushed and patted on the windshield while I pulled the rope, and it seemed to pop into place without any issues. (We'll see how well I did when I try driving it in the rain!)
I read some articles about using various tools and techniques for popping in the locking strip, and after attempting several of them, I decided to buy the tool that was designed for the purpose. I'll be doing all of the windows on two cars, so it just seems like a good idea.
Here are some pictures of the things I described.
Donations can be made to the Derelict Bavarian Fund.
