Thread Topic: Tin worms suck Threaded
Date: 6-12-07 04:17
From: Arshloch in Vancouver, BC View user's profile
Subject: Tin worms suck
Here is my little 68'. Originally a cali car, she appeared to have 0 to none rust when I purchased it. But at a closer inspection with a screw driver and a hammer, it revealed the hidden rot! And lots of it. Well, I guess it's time for surgery, I said to myself pulling out a grinder and a welder.
This car came with a good interior and decent repaint that I really did not want to mess up. This issue complicated pretty much everything except my floor job, as I could not afford cutting into my 1/4 panels and replacing the front fenders. When I cut her open, I realized that the car's rockers are rotting from the seams up and that issue will have to be dealt with later. Thats when I had to stop myself from replacing every panel on that car, meaning that I might as well restore the whole car!
68' 2002 DD
The inner fender was hiding heavy pitting-had to cut out. Another missing bracket.
 Filesize:  45.53 KB
 Viewed:  71 Time(s)
Put a really long patch into the column due to heavy pitting. I wish I could do a whole new column.
 Filesize:  40.52 KB
 Viewed:  56 Time(s)
Removed the rust and pitting on that side. Notice the missing bracket.
 Filesize:  43.93 KB
 Viewed:  54 Time(s)
 Filesize:  41.24 KB
 Viewed:  51 Time(s)
 Filesize:  48.07 KB
 Viewed:  59 Time(s)
Date: 6-12-07 04:29
Subject: Re: Tin worms suck (nt)
68' 2002 DD
"Some surface rust and no holes", yeah f&^%$g right! See, how much I had to remove!
 Filesize:  56.59 KB
 Viewed:  44 Time(s)
Made a 18 gage rocker patch and butt welded instead of damaged outer seal. The bottom of the seal is seam welded to the inner seal, so I dont have two overlapping peices rot each other
 Filesize:  32.31 KB
 Viewed:  57 Time(s)
Another shot . The fender will be attached with some panel bonding adhesive, unlike the original set up prone to rust
 Filesize:  39.31 KB
 Viewed:  39 Time(s)
After 2 hours of cleaning up the surface rust. Coated with POR-15 and 3M weld thru stuff.
 Filesize:  39.88 KB
 Viewed:  58 Time(s)
That black coating is a rust remover effect to protect against flash rust. I will clean it all up and coat with primer and POR-15
 Filesize:  43.47 KB
 Viewed:  48 Time(s)
Date: 6-12-07 04:36
68' 2002 DD
As you see, it was spreading onto the fire wall
 Filesize:  64.92 KB
 Viewed:  63 Time(s)
I love the " bumperless look"
 Filesize:  41.24 KB
 Viewed:  39 Time(s)
The battery tray needs some therapy. So far the only rust under the hood.
 Filesize:  52.32 KB
 Viewed:  106 Time(s)
Removed all the rust and painted this. Also rebuilt the thing. Now is search for a new hose.
 Filesize:  54.75 KB
 Viewed:  36 Time(s)
The ugly pedal box after acid treatment and a few coats of POR-15. Only one bushing needed replacement.
 Filesize:  56.1 KB
 Viewed:  43 Time(s)
Date: 6-12-07 04:48
To my surprise that surface rust on the 1/4 spread all the way up the roof pillar and probably inside the roof. In a few years I might end up with a hole in roof. He he.
68' 2002 DD
Some rust treatment.
 Filesize:  42.27 KB
 Viewed:  44 Time(s)
Date: 6-12-07 08:24
From: jmon0261 in Chico California View user's profile Send e-mail
Well- Keep slugging away at it !!
It will be worth it when you have it back on the road.
People have used; E 30 spare tire wells-
You can have a full size spare.
Might be easier to find.
Should be a thread here on the FAQ.
Good Luck !
Joseph O'Neil
73 02 - Polaris - driver
67 2000 TiLux- Chamonix
Date: 6-13-07 07:45
I have a 4 speed and a battery tray available plus other odds and ends on Ebay.
Date: 6-20-07 12:24
Looks like yo need to upgrade your air filter...restrictive is the wrong word to use i think.
lol ;)
http://www.bmw2002faq.com/component/option,com_forum/Itemid,50/page,download/id,13390/
1974 2002 auto
1997 Pathfinder
Date: 6-20-07 03:24
Thats a K&N, came with the car. I also have the stock one.
Dont know how restrictive it would be, but I have see similar but smaller ones on minis set up the same way. And that one on there is the size of civic cold air intake.
68' 2002 DD
Date: 6-20-07 03:47
I know what a k&n is. Even if you saw this kind on other cars, IT IS restrictive as hell.
Go on their web site and use the calculator, it will tell you the surface area of the filter you need so it will not be restrictive. All you need is to enter few parameters such as engine size.
1974 2002 auto
1997 Pathfinder
Date: 6-20-07 04:29
It shows 3 by 3.5 at 5500 RMP. This thing is a tad smaller.
I honestly think that a stock air box with an after-market filter and the snorkel will do just fine at higher RPM. I dont want to mode this thing or anything like that, she is too old for that. All that Ill do to it is the brakes, springs, shocks and bushings.
68' 2002 DD
Date: 6-26-07 12:01
Oh trust me, thats the fun part! I dont have a 02 but I actually think working on rust and rot is fun. Thats definity a great car to start with, good luck.
"Drive Fast and Take Chances"
