Thread Topic: idle speed screw and hesitation question Threaded
Date: 10-12-05 05:54
Subject: idle speed screw and hesitation question
where is the idle speed screw. I have the weber manual and only see the idle mixture screw. is it called something else? I have hesitation when climbing hills what do I need to do to tune this out? Can I tune this out?
Date: 10-12-05 05:55
Subject: more info
115 main jets, F11 emulsion tube, 55F8 idle jets
Date: 10-13-05 02:48
Subject: are we talk'in hills of colorado ?
or beverly ?
please list the MAIN Jet ?
Air Correction jet sizes?
which carb? 32/36? , 38/38? ,
other ?
what's yer float level at ?
how's yer ignition timing set ?
valve clearance ?
Date: 10-13-05 09:29
Subject: Re: are we talk'in hills of colorado ?
area: nashville, TN
Dual 40DCOE
what's yer float level at ? don't know how do you check
how's yer ignition timing set ? don't know how do you check
valve clearance ? don't know how do you check
Date: 10-13-05 10:41
Subject: WEBER - DCOE's------P.L.E.A.S.E.-----sombody help Matt here-----
..here's how to adjust the float levels.
Date: 10-13-05 11:52
Subject: idle speed screw?
The Weber book references and idle speed screw, is there no such thing? CD thanks for the float level diagram. Is there a special tool to measure air flow into each carb? If so where do you get it at?
Date: 10-13-05 03:31
Subject: e-mail sent with full color picture(nt)
