Thread Topic: Brake upgrade question...read the faq Flat
Date: 10-14-05 11:03
Subject: Brake upgrade question...read the faq
I have some questions about the brake upgrade FAQ
parts listed to get for a non Tii are as follows:
# New 1977(only) e21 Vented rotors
# Used 1981-83 e21 Hubs
# New or Used Girling Vented Calipers for a mid-80s Volvo 240 with VENTED brakes.
# New brake hoses
# New wheel bearings
# Wheel bearing grease
# New performance brake pads
# Two pints of new brake fluid
# Four 1" standard galvanized or stainless steel washers
What is the hub? what are the washers for? brake pads for the volvo 240 calipers, right? and what model would I get wheel bearings for? the 320i, or the 2002 that I own?
      answers... - MartyR - 10-14-05 11:13
            I don't get it... the washers are used to center the calipers over the - Tom Winston - 10-14-05 11:19
                  brake disc = rotor, .... - MartyR - 10-14-05 11:26
                        4 POTS? meaning they are 4 piston like the 2002 stock? - Tom Winston - 10-14-05 11:42
                              No need to swap lines. You'll be plumbing the two rigid lines... - MartyR - 10-14-05 11:58
                                    Tom-sent you an email about altenator(nt) - matt - 10-14-05 11:59
                                          thomas.j.winston@jpmchase.com(nt) - Tom Winston - 10-14-05 12:02
                                    2 rigid lines directly into the calipers? - Tom Winston - 10-14-05 12:02
            well then.. - matt - 10-14-05 11:20
                  the 02 front hub/brake rotor is not "conventional"... - MartyR - 10-14-05 11:28
      MATT, email me at my work address - I'm working the after-hours - Tom Winston - 10-14-05 12:23
            email sent tom, thanks.(nt) - matt - 10-14-05 12:28
This forum is locked: you cannot post, reply to, or edit topics.    BMW 2002 FAQ Forum Index > Archive Flat
