Post new topic    BMW 2002 FAQ Forum Index > Off-Topic
Thread Topic: e30 help! Threaded
Date: 7-25-08 07:00
From: ash00 in San Jose, CA View user's profile Send e-mail
Subject: e30 help!
I tried searching most of the e30 forums, and all I could find are attacks on people and how to convert to short bumpers or buy ellipsoid headlights. Arg!
Does anybody have any tips on how to remove the instrument cluster, and what this "SI" battery is/where it is/what kind it is?
Thanks!
Aashish
1969 BMW 2002--I gotta finish this damn thing
1988 BMW 535is--I feel like a cocaine dealer in this
1991 318is-- uber fun
1975 Innocenti Mini 1001-- Tiny magnifico!
2004 Toyota Tacoma (gotta have something reliable!)--can't live without
Date: 7-25-08 07:14
Subject: Re: e30 help!
winstont AT direxionfunds DOT com
Ash,
same as the 2002 but with a little more trim. You have to take off the steering wheel - do you have an airbag wheel (i hope not)... pop off the roundel, remove the wheel, there will be a few little phillips screws up under the top piece of trim, remove that and the outer trim cover will come out. I think (its been a while) that you have to remove a piece of trim between the gauge cluster and steering wheel column - that is held in with a few nuts behind like the cluster in an 02 is held in.
re-reading i'm seeing that this is a pretty piss-poor description... you could go to a junkyard and tear one out to learn how???
Email me if you have questions - its easy... if you can do brakes on an 02 you can remove the cluster on a n e30.
Battery you are looking for is behind the cluster IIRC.
BMW-Yachtsport
'07 Accord DD
Date: 7-25-08 07:20
thanks!
I found a pretty good tutorial:
http://www.beckerelectronics.com/SIboard/siboard.html
this is blunt's old car, so luckily the steering wheel comes right off. I may try at a junk yard first though for fun. Who knows, I might find something I need anyway!
Aashish
Date: 7-25-08 09:34
From: gwb72tii in the great PNW View user's profile Send e-mail
if you do have an airbag steering wheel, MAKE SURE to disconnect your battery first, otherwise the idot light about SRS will be flashing and then remain on permanently every time you drive the car.
euro ellipsoid headlights, BTW, are a huge improvement over stock sealed beams, or for that matter Hella H4's, especially with a higher output light source like Sylvania Bluestar. They are spendy, but the euro smileys are great looking, have a city light built in, and are first class headlights for driving at night. VERY HIGHLY RECOMMENDED.
gwb72tii
Whenever you find you are on the side of the majority, it is time to pause and reflect.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
Date: 7-25-08 09:44
don't get me wrong-- Blunt had them on his e30 and they are fantastic. Aside from being yellow, they are really cool.
Aashish
Date: 7-25-08 04:23
Even if you have a NON airbag wheel - make sure to have the key in the ignition and the steering collumn unlocked - only then will the wheel be removeable from the splines!
Pretty easy job - but be patient and gentle with all that plastic / delicate stuff.
Paul Wegweiser
Date: 7-26-08 10:16
yeah I had a problem last night with that plastic panel thats right by the steering column. What a @(#$%U@#$. I have to read up again to see how its done. I don't want to break it!
Aashish
Date: 7-26-08 09:52
From: jonny in Connecticut View user's profile Send e-mail
2 aluminum thumb screws hold the panel right below the cluster.
I've done it 30 times.
Take our time at first.
Then you'll be doing it wiff your eyes closed.
'72 02 Weber
'75 Opel Ascona Weber S
'82 e21Weber S
'84 535iS
'86 535i Uber Beater
'89 325iS
(2)'89 325iC's
15+ parts cars
http://myworld.ebay.com/fosters.3
Post new topic       BMW 2002 FAQ Forum Index > Off-Topic All times are GMT - 7 Hours
