Thread Topic: Piston Prices/Availability Threaded
Date: 7-24-08 05:29
Subject: Piston Prices/Availability
Does anyone know of any other sources of pistions than these here?
I'm going to need +.5 mm pistons for my rebuild. My machinist says that should be enough to ensure that the new rebore is consistent from top to bottom. But, even after searching the forum and the web, it appears that most of the pistons have dried up.
I've seen posts from the past that quote about $400/set for Mahle cast pistons but I can't find those at Zygmunt, Mesa, Pelican, or others. Does anyone have any insight or different info? Is it the falling dollar, lack of demand etc.?
Does the $400 piston set only exist at Bavarian Autosport, in which case you have to get the rods honed to fit the new wrist pins?
Here's what I found:
    Maximillian $244 each
    Autohauz AZ $126 each (1977 320i)
    2002ad $595/set (tii)
    Ireland Engineering $520/set (tii on backorder)
    Bavarian Autosport $350/set (wristpin bore required/sub-standard rings?)
Thanks for the input
John in Eastern NC
1976 2002 Chamonix/Navy
Date: 7-24-08 05:36
Subject: Re: Piston Prices/Availability
Recently, all the oem through normal parts chains have dried up.
Wish I'd bought a few sets, but then, money's money.
Ireland will have a set of Ross made for you for $600- they're forged.
MaxSil's are a lot less, with decent reviews for stock-ish applications so far.
fwiw.
Date: 7-24-08 05:42
Are you after flat tops, or what type specifically?
Date: 7-24-08 06:03
I'm looking for a decent, quality set for street use. Nothing fancy. Flat tops or tii, whatever I can get. If the tii ones are $50 more, then I would buy them, but probably not for $100 more.
John in Eastern NC
Date: 7-24-08 06:23
From: kbmb02 in SoCal View user's profile Send e-mail
Couple things . . . as I understand it, Ireland is working on having new cast pistons made for the M10 though I don't know the pricing. See link below, perhaps they'd have more info on the phone.
http://www.iemotorsport.com/coming-soon.html
Alternately, I've got a set of used over-sized flat tops in the garage, if you don't find anything else email me and I'll check specs and take photos.[/b]
Date: 7-24-08 07:12
fwiw.
Are Ross pistons good?
And what rings do you get with the Ross pistons?
-Old Skool-
Date: 7-24-08 07:46
From: gwb72tii in the great PNW View user's profile Send e-mail
tii mahle's are NLA
i tried for a month to find any set anywhere
have you tried zygmunt?
gwb72tii
Whenever you find you are on the side of the majority, it is time to pause and reflect.
Mark Twain [Samuel Langhornne Clemens] (1835-1910)
Date: 7-24-08 08:29
The Mahle pistons are not currently available and maybe will never be. We have made a large run of cast pistons that can be configured for any combustion chamber and any compression up to 10.5 to 1. The diameter is 90mm (1 mm over). We will have them available within 2 weeks. Cost will be very competitive. More info on our website later next week.
Date: 7-25-08 04:52
Subject: Jeff--so your new pistons will work with the 121 head? (nt)
Date: 7-25-08 09:53
Ross pistons do seem to be good.
They are forged, though, so a good warmup is required,
as cold fit is a bit looser than a cast piston.
They use thin Ross rings.
So far, they are working great- in the race car...
Date: 7-25-08 03:43
I have a new NOS set of Hepolite bathtubs and a set of Kolbenschmidt flat tops. Both are 1st oversize (I need to confirm).
giantkillerracing@gmail.com
Anthony
Date: 7-25-08 06:05
From: Napes in Nogales, AZ View user's profile Send e-mail
The guy who built me an M10 engine recently was able to get 9.5:1 Mahle pistons thru his conections in Germany. They were not cheap, though, and I doubt that he's willing to share his source. But, they are out there.
Bob Napier
Date: 7-26-08 08:37
Subject: Re: Jeff--so your new pistons will work with the 121 head? (
Yes we can machine the top to any combustion chamber shape and compression.
Jeff
Date: 7-26-08 09:38
The following FAQers could contact "mac" re. piston availability IF they need/want good pistons.
GWB72Tii
mike in beavercreek Ohio
EWN2002 in New Bern NC.
email him at macitz Att core Dott com.
mac.
Date: 8-29-08 08:22
Just ordered a set from Ireland Engineering last night. Looking forward to receive them in a few weeks. Great prices, starting at $320.
John in Eastern NC
