Thread Topic: Electrical gremlins Threaded
Date: 7-25-08 02:09
Subject: Electrical gremlins
Newbie to the whole posting thing, with a question for the electrical gurus.
H20 temp gauge, Alt light and blue high beam light does not work. High beams DO work, when I turn key on the H20 needle does move a hair, so there is voltage to it.
The odd thing is the fuel gauge, oil light, and the turn signal lights work.
I have swapped out the gauge with a runner , and the same.
What would cause half the gauge to work? BTW, also swapped the sensor on the block to no avail.
Appreciate any suggestions.
TW
Date: 7-25-08 03:41
From: jgerock in Alexandria, VA View user's profile
Subject: Re: Electrical gremlins
As with everything else on these cars - check and clean the grounding points. Most of the time, it clears up all the "gremlins". Use contact cleaner after you've scratched/wire brushed/sanded the grounding points.
BMWCCA # 381868
73tii "Celeste" # 2764081
71 VW Bug
Date: 7-25-08 04:12
It sounds like you're familiar with removing the gauge cluster. Once you pull the cluster, examine the fuel/temperature gauge circuit board on the side facing the instruments. Mine had a burned-out trace (looked like a blown fuse strip) which caused one of the gauges to not function at all. I think it was the fuel gauge, but don't remember. I soldered a piece of wire across the gap, added the frequently described brass nut ground wires, and it's been working fine for 10 years.
Jerry
Date: 7-25-08 09:56
From: Chris_B in Scotts Valley, CA View user's profile Send e-mail
This is a bizarre problem, for sure. When you say that you "swapped out the gauge," do you mean that you replaced the temp gauge itself, or the whole instrument panel? The fuel and temp gauges share the ground, and the warning lights are on independent circuits. Also, generally if your charge light is burned out, your charging system will not work. I presume your charging system is OK, since you did not mention that. It could be that you have more than one problem going on. Are any of your instrument panel lights in that part of the panel non-op?
Chris B.
'73 ex-Malaga
Date: 7-26-08 12:09
Subject: As has been pointed out, all the gauges go thru the same
fuse, so it shouldn't be a fuse problem. After you've checked the other things mentioned (grounds, bad bulbs) I'd carefully examine the multiprong plug that all the cluster electrics pass through. Look at the end attached to the car's wiring harness, and the socket on the cluster that the holds the harness plug. Sounds like some of the pins aren't functioning, have corrosion or perhaps have come loose from the circuit board.
Date: 7-26-08 04:56
Subject: Re: As has been pointed out, all the gauges go thru the same
Thanks for all the tips, as I rooted around, I found the culprit. The little five prong plug that is right behind the heater/defrost tube against the firewall was disconnected. I couldn't see it at first, but when I took the heater box out, for a completly different reason I said 'your kidding right?'
Anyway, all is good, and thanks again.
TW
