Date: 6-10-08 09:44
Subject: Re: 1974 automatic 4280905. UNDER SURGERY
The color question is the biggest debate right now.
Sahara is not that bad, but id like to have it something close to "grey mouse" as i use to say, it looks so vintage.
Audi has some nice gray on their TT, i will have my friend who works in a paint store look at it.
Probably Bristol, Fjord or polaris neu.
I will put on early style wheels with hubcaps as well for sure.
Believe me the body is not that bad, ive seen others way more bad, especialy my white one. _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
Date: 6-10-08 11:36
Mine is biscay blue
 _________________ 70 2002 w/m42
91 318is w/M50
Date: 6-10-08 01:18
very nice...
i am looking at something more grayich... _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
Date: 6-10-08 01:31
the color i am talking about is aviator gray from Audi (TT) _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
49.29 KB |
11 Time(s) |
Date: 6-28-08 05:39
today update...
i spent a lot of time adjusting the fiberglass fenders, and making them look straight.
I also fixed the rear left shock tower and also the top of the nose near the rad. That portion has been saw zalled by po for a very obscure reason, probably to reach the nuts of the center grille...i couldnt look straight so i had it sprayed with gravle guard, then the sprayable bondo over that will striaghten it a lot.
Next will be to fix/adjust the front bumper once i will receive some known good source bumper ends.
I still didnt find the source of the one i have. grrrrrr.
Soon i will spray over a coat of spryable light bondo, will get it surfaced straight then primer...i cant wait for this day to come...i am a bit late on this project. _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
351.31 KB |
10 Time(s) |
443.65 KB |
11 Time(s) |
327.26 KB |
11 Time(s) |
372.94 KB |
12 Time(s) |
420.91 KB |
11 Time(s) |
Date: 6-30-08 06:30
i have photoshoped the stickers unique to the car... _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
260.07 KB |
6 Time(s) |
215.65 KB |
6 Time(s) |
175.2 KB |
9 Time(s) |
175.81 KB |
8 Time(s) |
198.02 KB |
6 Time(s) |
Date: 6-30-08 08:21
Its coming along nicely Pat - im enjoying seeing this car coming back to life.
Tom _________________
Date: 7-1-08 05:38
| oz_tom wrote: | Its coming along nicely Pat - im enjoying seeing this car coming back to life.
Tom |
Thanks Tom...i am late on that project, i just hope i will finish it by the end of the summer.
For the ones who download the stickers jpg: be warned, they are far from beign perfect, i am not a pro graphist at all, they could benefit from beign reworked/perfected.
Thanks. _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
Date: 7-1-08 07:52
| PatAllen wrote: | | For the ones who download the stickers jpg: be warned, they are far from beign perfect, i am not a pro graphist at all, they could benefit from beign reworked/perfected. |
Good thing I'm a designer with a little free time (man, I should be working right now!)
jpegs are low-rez, if you want the high-rez ones download the .zip file here: (2.3Mb)_________________
42.28 KB |
6 Time(s) |
44.89 KB |
6 Time(s) |
Date: 7-1-08 08:42
| H_Krix wrote: | | PatAllen wrote: | | For the ones who download the stickers jpg: be warned, they are far from beign perfect, i am not a pro graphist at all, they could benefit from beign reworked/perfected. |
jpegs are low-rez, if you want the high-rez ones download the .zip file here: (2.3Mb) |
Thanks H_Krix !! _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
Date: 7-22-08 02:25
small update...i didnt spend all the time i wanted...its summer time, vacations, i am lazy, too much beer,...
I removed what was left from under the hood so i can clean the firewall and all the rest.
I was not supposed to go that far under the hood. I told myself...why not. _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
397.31 KB |
5 Time(s) |
351.94 KB |
4 Time(s) |
336.66 KB |
5 Time(s) |
350.02 KB |
12 Time(s) |
Date: 7-25-08 01:38
First coats of "reface" stuff...light sprayable bondo.
I blocked it all 2 times to mask all imperfections.
This car gona be straight.
It requires a lot of elbow grease as i do it all manualy. Pff !! _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
251.95 KB |
6 Time(s) |
288.9 KB |
5 Time(s) |
300.2 KB |
6 Time(s) |
Date: 7-27-08 02:20
Subject: BUMPERS ON !!
yup, elbow grease. thats it.
What i do IS a restoration. Taking a new a like shell and putting all new parts on it is just an exersice of showing that you have deep pockets...i do not btw.
So today i fitted the ?%$?@#? bumpers.
It is just the pre-test fit so i know if it gona be ok or not...i like the overriders-less look.
Hey, who is looking at me up front...yeah, my white 02 of course... _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
432.45 KB |
6 Time(s) |
495.75 KB |
6 Time(s) |
271.19 KB |
7 Time(s) |
262.13 KB |
5 Time(s) |
297.5 KB |
5 Time(s) |
Date: 9-28-08 02:50
Update, i didnt touched the car for the last month or so....my gf is pregnant...
i found some time this weekend and finished up the front nose and the slots for the bumper brakets.
i also poured some build-up primer on the trunk lid. all blocked down and straight.
i also seam sealed all the joints of my fixes on the floor pans. aouf.
sorry, no pictures yet. The plan is to have the car painted before the snow gets in.
wish me luck... _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
Date: 9-29-08 09:12
well, both !!
thanks !! _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
Date: 9-30-08 05:50
HI PAT, GREAT TO SEE ALL YOUR HARD WORK AND THE OLD GIRL COMING BACK TO LIFE. BRAD KRAMER IN ONTARIO, P.O.
Date: 10-1-08 07:08
| PO wrote: | | HI PAT, GREAT TO SEE ALL YOUR HARD WORK AND THE OLD GIRL COMING BACK TO LIFE. BRAD KRAMER IN ONTARIO, P.O. |
hi M Kramer, nice to hear about you !!...i didnt knew that this car was a female...lol...
M. Kramer is the last known user of this car, back in 1992...how cool is that !!
yesterday i sandblasted the hood so it is now ready for preparation. My hope are that for the next week the whole car will receive its first coat of primer... wheuuu heuu !!!! _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto
1997 Pathfinder
