Thread Topic: long call:pick-n-pull guys, need a E30 325e part... Threaded
Date: 7-25-08 02:23
Subject: long call:pick-n-pull guys, need a E30 325e part...
To anyone who know a E30 325e car at a pick-n-pull, i need the tortional vibration damper that is mounted at the tail of the trany, right next to the guibo.
part #3 on the picture.
this is mostly found on late e30, there is two kind of this, the one from the 325e is a bit different.
So i realy need the one from the 325e. if you have the one from the 318 i may be interested as well.
thanks
1974 2002 auto
1997 Pathfinder
 Filesize:  51.58 KB
 Viewed:  21 Time(s)
Date: 7-25-08 05:13
Subject: Re: long call:pick-n-pull guys, need a E30 325e part...
I've eliminated those on countless BMWs over the years. Just take the studs out and get 3 more bolts.
If ittt grunzz vit out itt, itt dooon'ttt neeed ittt. :) An old German mechanic I met one time said that... stuttering accent and all.
Tom Jones
BMWCCA Life 49246
Vacaville CA
67 1600-2 Granada
+ 3 more 1600-2's
67 1800A stored
76 2002 F/S soon
86 528e 5sp Mine 369k
86 528eA Wife's
90 CRX HF 50mpg!
Date: 7-25-08 05:31
and the purpose of your intervention is ??
you want to tell me that you have one since you remove them all ?
1974 2002 auto
1997 Pathfinder
Date: 7-25-08 06:02
Sorry, I only remove them from the car when they're bad. I wasn't meaning to be bad or anything...
I am planning on visiting a couple of PNPs tomorrow and will keep my eyes peeled for a good one. Are you looking for... #23 13 1 220 584 ?
that's the one that goes with guibo #26 11 7 511 454 Not the "normal" e30 guibo # 26 11 1 225 624 right?? The one that goes with the "624" guibo is #
the "454" guibo is used until production date 5/86 whereas the "624" is used after that date.
So, I'm going to look for a good "584" dampening ring.
HTH
Tom Jones
BMWCCA Life 49246
Vacaville CA
67 1600-2 Granada
+ 3 more 1600-2's
67 1800A stored
76 2002 F/S soon
86 528eA Wife's
90 CRX HF 50mpg!
Date: 7-25-08 08:07
From: instructorbill View user's profile Send e-mail
I've got one from a 325i convertible... if it'll do I'll send it to you!
Make it different... or just do it differently
Bill in Petaluma, CA
Date: 7-25-08 09:24
well, i am confused with the pn's. The one i need is the one that is not surrounding the guibo but is "outside" of it...otherwise send me the one you have, as it is for a project.
you can contact me off line plz.
Did you know that a 6 bolt guibo on a 5 speed od e21 is the same as a e30 and a e36 guibo ??
thanks very much !!
1974 2002 auto
1997 Pathfinder
Date: 7-25-08 11:32
this one surrounds the guibo-- You still want it?
Date: 7-26-08 12:29
From: M350i in Egypt / Switzerland View user's profile Send e-mail
for the PN# check www.bmwfans.info
for the dampener itself check with the www.e30tech.com people ;)
No expectations , No disappointment
Greetings
John
Date: 7-26-08 06:40
yup, how much ?
i still need the one from a 325e too.
thanks !!
1974 2002 auto
1997 Pathfinder
Date: 7-26-08 09:05
I'll just want shipping
Mail me at the link in my header
Cheers!
Bill
Date: 7-28-08 06:53
i sent you an e-mail instructorbill.
let me know.
Thanks.
1974 2002 auto
1997 Pathfinder
Date: 7-28-08 06:54
HTH
Tjones, wathever you find let me know plz.
Thanks.
1974 2002 auto
1997 Pathfinder
