anyone need some crap?
just took photos of some leftover junk from the car I tore apart
PREFER local pick up in SOCAL - I can bring basically any of this stuff to anyone that goes to the Cars&Coffee events in Irvine on Saturdays, since it's real close
basically none of this stuff is in awesome shape, just FYI
i'll try to answer any questions in here
make offers if interested
one bolt/screw receptacle cracked on this, was in use for previous 3 years
steering box needs to be rebuilt. arm is still attached and will include idler arm as well.
32/36 is jetted to CDs settings, but is missing the fine fine threaded nut that secures the throttle parts. includes electric choke. will throw in a water neck as well.
vacuum advance dizzy. i used it w/o vacuum attached, and i doubt it works properly anyway, but ran just fine on my car. does not include igniter.
standard size rod bearings. not used, because they were the wrong size for my crank. 2 shells were used to check clearance w/ plastigauge, but all are new.
new in box timing chain guide and rail
floor boards... what you see is what you get.
trim pieces.... chrome is gone. lower belt line stuff is free; not all in good shape
grille set... can be cleaned up, kidney grill is no good but will toss in free
weber adapter w/ bolts included
weather intake selector deal is free, as is the tank fill boot thing
standard glove box...
corner lenses
ash tray and heater box tubes are free
2002 emblem. other stuff is free.
free headrests if you pick em up (or go to C&C)
free bumper stuff if you pick em up (or go to C&C)
shocks have already been shortened, but not welded or drilled otherwise
jack and wheel wrench are free.
free shift console, but is missing the metal shift boot flange
free passenger side rear panel, w/ chrome strip
1969 2002 Automatic w/ Sunroof "pumpkin"
1974 2002tii #2782677 (being assembled)
