| Benz02 wrote: |
Hey all,
I'm trying to figure out what year it is. The head is stamped '83, it's the block I'm wondering about. The VIN stamped on it says 1255223 (which doesn't seem to correspond to the production Vin numbers), however there are other numbers in a circle, and a number 73. Just above the starter mounting point, there is a blank spot, looks like it should have a VIN stamped there, but only has a small "X" and some other little weird symbol... |
At risk of putting words in your mouth, let me guess at what you really saw & what it means..
The first "VIN" you saw "stamped" was neither stamped or a VIN. This was no doubt the raw casting number that appears (cast) above the rear freeze plug on the right hand side. You can see the same last six digits in the photo I've posted below. This 1255223 is not a BMW part # or a vehicle identifier, but my photo does happen to be from a 1973 block.
If you want to know the year, at least the year the block was cast, that was the "73" number you found. Of course, that block could have been used originally in either a 73 or 74 model year car when new. At some point your engine got a later head. It may be a factory rebuild, but it could just as well be the salvage dealers erasing any traceable link as default protection from insurance recovery.
60.6 KB |
9 Time(s) |
