I am trying to hook up power to a radio in a 1976 2002. I found a line coming to a terminal block (on the interior firewall near the steering column penatration) that is hot with the key on. The problem is, it has power only intermittently. Must be a gremlin. I checked the fuse and it is OK. Where is the relay, if there is one, that powers this line or any other line I can use? Is there another possible reason than the relay?
This is the wiring diagram that I am using.
http://home.comcast.net/~randymolson/02wiringdiagram-76.pdf
The hot lead with the key on comes from one of a three prong connector block that is also under the dash by the steering column. I think it is #63 on the wiring diagram.
Of a smaller concern, how do you get a hot lead that connects to the instrument lights dimmer switch so that the radio face light can be dimmed. Thanks in advance!!!
