Thread Topic: gauges whats the deal here? Threaded
Date: 5-11-08 02:51
Subject: gauges whats the deal here?
hey guys and gals. i think this is about my 4th post here. i have been lurking/ using the search button way too much. haha. anyways, i have a 74 02 which i am in the process of restoring. the only problem is the gauges are messed up. the tach works, the blinker/ brake/ "L" lights all work. the gauges that dont work are the gas level, the speedometer, the odometer and the temp gauge works, but takes forever to get to the middle/ driving temperature. what is goin on?
i have read about the speedo cable, but it was working when i got it out of the shop for about half a mile, then died. the gas level sometimes works and goes up and down when i press the brake...
Date: 5-11-08 05:05
From: fiftytakedowns in San Rafael View user's profile
Subject: Re: gauges whats the deal here?
Have you ever takken then intrument cluster out of the dash, and inspected the gauges?
I recommend that too. I fixed some of my problem swith sjust bad connections, and loose wires.
1974 tii "Mr. T"
Date: 5-11-08 06:52
not yet. i dont know how to take the whole dash out (one piece). i did find out my speedo cable is broken. so thats on my list of things to order. would the speedo cable effect the gas gauge/ odometer?
Date: 5-11-08 07:36
From: 76duece in Westchester, NY. Land of SUVs View user's profile
Reach up under the dash, by the steering wheel. You will find two knurled thumb-nuts. These hold you instrument cluster in place. Remove them, plus the speedo cable that has a similar thumb nut(but longer, barrel shaped). Push from the back of the cluster, and it should pop out. Now you can get to your wires. Good luck.
Larry
Date: 5-11-08 07:57
Subject: gauges here's the deal ...
Speedo and odometer are driven by the same cable--if it's broken, neither will work.
flickering gas and temp gauge are usually caused by a bad ground to the gauges. Run a separate ground wire from each gauge to a ground point on the body...lotsa archive info on that.
If it takes your car a long time to warm up, then your thermostat is probably bad. New ones are readily available and easy to install...
Good luck, and don't be shy about asking more questions...that's what the FAQ is for.
'69 Nevada sunroof--"Wolfgang"
'73 Sahara sunroof-- "Ludwig"
Date: 5-11-08 09:29
Subject: Re: gauges here's the deal ...
thanks guys. i will keep ya updated. im a frequent member over at BF.C. i usually only post questions when i know there hasnt been a exact topic like it. i hate when the same questions get asked 100000 times. 100 times is ok though.
