got my tii back from accident repair- rolled on the rhs and aside from other repairs the roof had to be straightened. everything looked ok until i test fitted the sunroof transport mechanism (everything except the sliding roof and crank mechanism). there was a lot of resistance moving the sliders by hand- i believe they should move freely without the crank mechanism installed? (new cables and cable channels cleaned and lubed).
i'm going to check all the alloy pieces (items 1,2,3,4 in
http://www.realoem.com/bmw/showparts.do?model=2232&mospid=47131&btnr=54_0217&hg=54&fg=05) and the body surfaces where they mount in the sunroof cavity for possible accident damage, checking to make sure they are straight and level and there's no buckling in the body sheet metal.
question: am i right to assume that the long fore-aft alloy pieces (item 4 in the realoem diagram) should be dead flat and so should the body surfaces where they sit on in the sunroof cavity? not sure if i've described this well enough. would really appreciate your comments, experience. everything's off the car including the roof lining and i just want to make sure the sunroof works properly before putting everything back on.
tia
74tii
