Date: 12-11-05 07:26
Subject: PARTS PARTS PARTS
hi group. I have acquired a shit big pile load of parts. Anything. They were going to garbage. So i took them out for cheap.
I will try to organise them so i will know better what i have,
on the top of my head...
-Starters
-Alternators
-all kind of lights (front+rear, round tails, reflectors,...)
-all kind of dash switches, flasher switches,...
-instrument clusters, all models (except turbo ;)
-2 dash, one Tii with its clock, a bit cracked (still decent imho), and one non tii, not cracked, both one piece type
-switch stalk covers, many different models (pre 70, 70-72, 73-76)
-brake boosters
-calipers, all kind (tii and non tii)
-clutches parts (mc, actuators, tubes)
-windshield washer bottles, VDO type (2)
-windshield washer pump, many different models altough they all seems 02
-shifter platform, boots, knobs, many different models
-Distributors, many different models, some with vacuum, some not, some with dual,...jfu4 jfud4 jfur4
-coil resistors
-Fuel pumps, 3 models
-all sort of relays, a big box of them all mixed up
-fuel sending units, i have 3 different length
-valvetrain components, rockers, valves, springs... tons of them
-heads...121, 1.8, e21 2.0, e12
-connecting rods, assembled, a lot of them
-rear view mirrors, 3 models
-subframe mounts
-engine covers (front timing chain, upper, distributor, water outlet, WATER VALVES !!)
-ventilation parts (ribbed tubes, fans, switches)
-gas pedal
-console parts, side panels, speaker panel, ash tray with mounts
-wheel hubs
-oil pans
-oil pump parts-hand brake cables
-differential mounts
many many misc parts, box of bolts, nuts, brakets,... _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
1974 2002 auto (under resto)
373.82 KB |
10 Time(s) |
373.07 KB |
17 Time(s) |
379.44 KB |
8 Time(s) |
372.94 KB |
13 Time(s) |
379.72 KB |
21 Time(s) |
Date: 12-11-05 07:29
Subject: other pictures... (nt)
(nt) _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
376.27 KB |
10 Time(s) |
378.12 KB |
8 Time(s) |
373.3 KB |
13 Time(s) |
374.79 KB |
9 Time(s) |
374.67 KB |
13 Time(s) |
Date: 12-11-05 07:33
Subject: Re: other pictures... (nt) (nt)
374.46 KB |
12 Time(s) |
370.73 KB |
9 Time(s) |
382.9 KB |
11 Time(s) |
374.01 KB |
13 Time(s) |
Date: 12-11-05 07:57
Subject: Re: PARTS PARTS PARTS
window regulator...i didnt see any.
I have to go back to this guy after the holidays for another load, maybe i will get fews..??
The deal with all these parts...i offer them to anyone who needs some. I know many are just big shit garbage, but heck, i got them for very cheap !!!
If you need something, think twice then offer me something that i cant refuse!!
My goal is to not keep them until i will die, like from the man who i got them, but to put them to good purposes. If i can get few bucks for what it can worth, its gona be ice on cake.
btw, i may need some e36 parts, exchange is always possible !!
Next month or so, i will get few engines, short, long, transmission and differentials.
I know for sure that there is a complete seized Tii motor, with all the fueling on it.
Pat Allen
patallen@aei.ca_________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
Date: 12-11-05 08:13
Subject: Re: what kind of prices are we talkin?
| bimmerboy wrote: | id be interested in how muc hyou want for the tii clock, a complete console(if you have the pieces), and a vdo washer bottle.
thanks |
I will ask you to wait just a bit before asking anything...i have not filed all the things i have and would like to do so.
For the Tii clock, i dont know if it is working, id like to sell it with the dash as a unit. I have several console parts (non a/c) so i am sure i could "build" one complete for you.
I dont know at all how much to ask for any of the parts. I have sold 2 years ago a Tii interior, door panels, dash without clock and few other things for 100$.
I know a Tii clock can worth "something".
I am located in south of Quebec, CANADA (~1h from Montreal)
I know this post may go to the "for sale" forum, but i didnt offered anthing for sale yet !!!
lol _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
Date: 12-12-05 07:23
Subject: Pat email me plaese. I wnat an e12 head...
If you have one thats strait and not cracked.
Date: 12-12-05 07:28
| canadapierre wrote: | You are such a tease... (agasse pisette, si je me souviens bien...) I'm interested in a 1970 low/high beam switch and whatever is needed for intermittent wiper setup.
So when you dooooooooooo post it on the for sale site, consider this my interest! I have plenty of loose Canadian Tire money I can part with. If need be, I just recharged the color printer too... pierre in vancouver |
hi, i am sure i have all these parts, i just dont know what a 70 swtich looks like. i know i got one with a chrome knob at the end, most others looks the same, wich are all round like all the other ive seen before.
I got shit big pile of relays, so you may give me a bit more info about the one needed for the conversion.
hth _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
Date: 12-12-05 07:29
Subject: Re: Pat email me plaese. I wnat an e12 head...
| philv wrote: | | If you have one thats strait and not cracked. |
I think the one i have is a bare head (no valves or cam on it)
let me check tonight. _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
Date: 12-12-05 07:33
thanks |
Hi, can you e-mail me.
thanks
Date: 12-12-05 11:02
I would be interested in aTii brake booster or a rubber shift boot
Thanks
Date: 12-12-05 12:07
| Anonymous wrote: | I would be interested in aTii brake booster or a rubber shift boot
Thanks |
Who are you guest??
i do have aTii brake booster, it have been sand blasted and painted so it looks nice. What kind of shifter boot are you looking for?
e-mail me so i will be able to send you picture. _________________ 1976 turbocharged 2002, 14psi, T3, 70%LSD, urethane bush, 36x15 intercooler, 63mm tby,SDS EM4F, 5sp overdrive. Bilsts. Tech edge wb02, datalogger, recaros.
Date: 12-12-05 05:26
well, as long as i am happy, she dont ask much...
someone trash is someone else treasure??
i have already plenty of person who wants parts. Sooner or later, you will call me Lee, lol.
Date: 12-14-05 09:21
Do you have euro front turn signals.. Very interested.. If so, are you willing to ship to Toronto, Canada
Date: 12-15-05 07:16
No, i dont have these kind of flashers.
I was willing to ship, i am in Quebec !!
