Thread Topic: Squeaky sound when first starting up. alternator perhaps Threaded
Date: 10-15-05 02:19
Subject: Squeaky sound when first starting up. alternator perhaps
When I first start the car in the morning, I here a squeaking sound that seems to be coming from the alternator, possibly at the belt or pulley. Is there a place in there that I can lube easily or could it be a slipping belt? Once the car has warmed up a few minutes it goes away.
Date: 10-15-05 02:40
From: tkent02 in Littleton, CO View user's profile Send e-mail
Subject: Belts a bit loose or the wrong type...
BMWs use a funny angle in the V of the pulley, a belt from a different car will slip as not much of the belt actually makes contact with the sides of the V.
Tom
Something always leaks.
Date: 10-15-05 02:50
From: SteveH in Central New Jersey View user's profile
Subject: Re: Squeaky sound when first starting up. alternator perhaps
Your belt is worn, and/or loose. It may need to be tightened, but if you make it too tight, you will damage the water pump.
Does the sound happen when you blip the throttle?
76 2002 40 DCOEx2 292 Shrick
1984 Mercedes-Benz 300D Turbo Diesel 240,000 miles
Date: 10-15-05 06:02
Subject: How to find right tension?
The belt is really quite new, only about 10k miles so I doubt it is worn. Adjustment sounds more likely. Can anyone describe how it's done and what how to measure the correct tension?
Date: 10-15-05 06:18
Subject: Bad bushing, especially the lower ones, will cause that
start up squeel. The initial torque causes the alternator to shift, due to bad bushings, and scream at you to change them.
1972 2000tii Touring
1972 2002tii with A4 system
1972 2002tii found a motor
16' Mad River
Date: 10-15-05 07:03
Subject: wrong size belt and or alt. pulley not inline with.....
water pump pulley.
Rotten alternator bushings and alternator sitting
cock-eyed,
or,
Wrong size belt - your "V" is wrong = use 9.5 (is the"V" width size)
x 875 (is the length in mm) belt only
 Filesize:  87.93 KB
 Viewed:  14 Time(s)
Date: 10-15-05 10:31
From: cj in the BMW Sauber F1 car View user's profile Send e-mail
I second checking the alt. bushing and belt.
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
