Date: 10-13-05 01:52 From: Lars Subject: What thickness foam padding to use for rear seat back?
I am planning on replacing the horsehair padding in the back part of the rear seat to match the bottom part that was done by a PO long ago.
But I'm not sure what thickness to use, would an 1" be enough or should I go 2"?
How thick was the original padding?
Lars
Date: 10-13-05 04:34 From: phil vermeulen Subject: Re: What thickness foam padding to use for rear seat back?
you should first put down a couple of layers of the
grey felt padding. this is more dense then the foam
and will give support. then put the foam on top of that.
Date: 10-13-05 04:49 From: slx Subject: what work'd for me....
i lay'd a piece of indoor/outdoor carpet, short stuff, then used 1 1/2 inch foam
