Thread Topic: Okay, I give up. Please help me figure out this dimmer switc Threaded
Date: 10-11-05 09:33
Subject: Okay, I give up. Please help me figure out this dimmer switch.
1972 2002. Has blinker stalk on left (yes it does!!), dimmer on right. Dimmer stalk burnt out yesterday and was removed. Following number on the dimmer stalk housing:
1 352 957 8357/61
Recangular 3x2 junction with round pins, top center pin is a blank, so it's a five-pin connector. I do not know if it did anything other than dim the headlamps. I just got the car and it died after a couple of days.
A forum member suggested I have the older blinkers and that someone switched sides. Wouldn't that mean the blinker switch would be upside-down? It is not!
Another thinks I have a late-switch conversion. I admit I am only starting to look, but so far that part number doesn't match what I've found.
Any suggestions?
-Andy
Date: 10-12-05 04:53
Subject: Someone has really messed with your steering column levers...
All 72s came with right side turn signal levers; this lever also served to turn the wipers on and off (just on/off, not low/high speed--that was the lower right dash switch) and also the wash/wipe feature. The dimmer switch was always on the left on 2002s, even on the 74-76 cars that had left side turn signals.
From your description I suspect that someone has merely swapped sides with the two original levers. Easy enough to do if you move the "finger" (the thing on the back of the steering wheel that cancels the turn signals) to the opposite side. On roundies, the dimmer switch only selects low/high beams, plus has a heedlight flasher feature. There are two styles--early cars had individual spade terminals; later ones (like yours) have soldered-in wires ending in a multiprong plug. You should be able to use any similar dimmer switch from a later roundie--it should plug right in. And you should also be able to swap your levers back to their original sides by simply reversing them and their wiring harnesses (and moving the "finger").
Date: 10-12-05 11:31
Subject: Pins/Spades answers the question.
URL: http://pageproducer.arczip.com/mdyjc/BMW2002page1.html
'71-'73 used pins '74-'76 used spades. Someone has had the good sense to swap left to right. Makes it way easier to drive someone else's car.
Date: 10-12-05 04:30
Subject: Thanks guys, mystery solved!(nt)
