I got the wheels blasted and painted and suspension is now put together so you start to see what the car will really look like. It's very much like my vision was when I started this. Likely I will paint the wheel spokes/centers black.
Tires are 225/45/17 Michelin Pilot Sport 2, old ones just for testing. Most likely that's what will be used but if I end up with some other brand 215/45/17 may be an option (PSII not available in that size).
Also brakes are now installed, heated windscreen, dash etc.. Next electrical wiring.
What I'm worried about is that I'm still missing clutch and dry sump system. Both ordered from UK. Sump 3 months ago and clutch over a month now...
There's quite much work to fit those.
Also a little drawback with mainshaft. I made a one piece shaft and took it to be balanced. Thay said it can take max. 6000 rpm's before breaking, which would mean only about 150km/h. Larger diameter tube has to be changed...$$€€
Tommy
107 KB |
106 Time(s) |
108.48 KB |
103 Time(s) |
102.67 KB |
82 Time(s) |
95.75 KB |
92 Time(s) |
99.11 KB |
124 Time(s) |
