Having just finished removing the rear end, I started on the frame rail shown earlier. The original plan was (posted on Matts forum),
Basically all the rust is at the base of the frame rail (sitting water) and I intend on cutting this out keeping the sides intact. Then I am going to fabricate a 16 gauge U section which will fit between the existing sides. I then intend on welding the seam on the inside, and outside, to keep the strength......
However, as I started working I noticed the rust had attacked the sides of the rail too....this caused me to change the plan of attack, Now I know many people are going to say "this is crazy and will compromise the uni-body construction",,,,,however if this is done correctly, I believe it will be far better than the original rusty frame rails..
The new plan is to cut off the rusty frame rail and fabricate a replacement. This replacement will be welded to the original I will then internally strengthen by bracing the original rail to the new section with an L-beam joining the rail walls...Crazy? Yes!! fun? we will see..........
Now to fabricate the new rail I had to fabricate a metal brake.....which took a lot longer than predicted as 16 gauge is a pain to bend....
Heres the progress so far.
[/i]
114.86 KB |
5 Time(s) |
95.71 KB |
7 Time(s) |
85.57 KB |
8 Time(s) |
| The replacement frame rail in 16 gauge metal. The end still needs to be crafted so it it bends upwards and tapers like the original. |
94.37 KB |
7 Time(s) |
