Date: 5-17-08 04:22
Subject: Webber Dcoe's on my last nerve!!!
Guys I 've had it with the drafts, its powerful and all, and I do want to keep them but there's always something, so here is my problem, when I step suddenly on the gas from a complete stop, it bogs for a second and then it takes off maybe its because I only have screens in front of them and not air filters and it gets a lot of air, I don't know what the problem could be- I tried to show off today with a spinning start and it bogged down on its face. Help!!!!
Main jet 140
55F8
Rebuilt E21-1,8 motor with mild head work.
325.09 KB |
10 Time(s) |
Date: 5-17-08 06:20
Subject: Re: Webber Dcoe's on my last nerve!!!
Surely your car is exacting revenge due to being separated from it's Kugelfischer!
You know the remedy!
Cheers,
Ray
| Mr-2002tii wrote: | Guys I 've had it with the drafts, its powerful and all, and I do want to keep them but there's always something, so here is my problem, when I step suddenly on the gas from a complete stop, it bogs for a second and then it takes off maybe its because I only have screens in front of them and not air filters and it gets a lot of air, I don't know what the problem could be- I tried to show off today with a spinning start and it bogged down on its face. Help!!!!
Main jet 140
55F8
Rebuilt E21-1,8 motor with mild head work. |
_________________ '73 ///M2 2.5
'84 ///M635CSi
Date: 5-17-08 06:29
this is from my book "how to build and power tune Weber and Dellorto"
just highlighted this yesterday.
"A too small accelerator pump jet will cause the engine to die momentarily when the accelerator is depressed. Too large an accelerator pump jet causes the engine to 'bog', which effectively amounts to the same thing, (a slow car) and then pick up after the excess mixture has been removed from the engine"
"the following gives gives a basic starting range of accelerator pump jet sizes for modified engines (Ie with long duration camshafts, worked cylinder heads, high compression, extractor exhaust systems). Try the smallest jets first. The accelerator pump jets are listed as average, so expect to come down for sized for engines that are not overly modified."
Weber range for average use is 30, 35, 40, 45, 50, 55, and 60
500cc per cylinders (m10 ballpark): 45 on the high side, and 40's on the low side
that might head you in the right direction.
it gets more complicated with needles and stuff, but that's the basic guideline _________________ needy and demanding 72 02
Date: 5-18-08 02:43
| Mr-2002tii wrote: | | It's a E21 motor guy!!!! |
still, a tii needs the k-fish system- it's a matter of executing your custodial duties. i assume you 're not responsible for the wrong motor in the car; hopefully you do have some of the pieces, the proper block if nothing else. cut your losses now, and find the correct style k-fish system for your build number.
you'll thank me in the end.
robert w.
