Thread Topic: Floor Pan Rust Options Threaded
Date: 5-16-08 06:02
Subject: Floor Pan Rust Options
Is this the best option?
http://2002ad.com/storeworks/view_item.cfm?id=2025
I have a fair amount of rust in the floor pan, mainly around the drain (forgot the name, and I know it was not actually for draining). Is the shape of the floor really important (the indentations) or could I just make my own single bent sheet of metal, or just weld in patches?
Thanks
Merek
Date: 5-16-08 06:33
Subject: Re: Floor Pan Rust Options
any pics?
Date: 5-16-08 06:58
Not yet sorry, I'm going to try to have some up tomorrow.
Date: 5-16-08 08:52
If it's just where the "drains" are, I would just pop the old ones out ( hit them with a screwdriver and hammer and it will turn and come out ), grind away the rust, and cut off what you can.
Then cut a template out of cardboard, and trace it to a piece of sheetmetal, check the fit, and weld it in. Give it about a half inch of over lap as well. Paint it from both sides with an anti-rust paint, and Por-15 or equivalent.
I believe factory sheet metal is 20 gauge, but use 18 or even 16 if you can. I used 16 when I redid the floors on my chamonix, and it was a real pain to shape and cut, but the thickness of the metal help a lot in carrying the heat when I was welding. This helped prevent blowing though the metal.
-Andrew Poon
'72 2002
'76 2002
Date: 5-17-08 02:58
From: Jack in Westborough, MA View user's profile Send e-mail
And get a heavy piece of copper to back up the weld. The buss bar out of an old electrical panel works well, or cut a piece of 1 1/2" cu pipe and flatten it. Kinda prop it up under the area you are welding. It will make the welding much easier for you.
Date: 5-17-08 08:47
From: gwb72tii in the great PNW View user's profile Send e-mail
what's the purpose of the copper? heat absorption?
gwb72tii
If you don't know where you are going, you might wind up someplace else.
Yogi Berra
 Filesize:  74.28 KB
 Viewed:  1 Time(s)
