You want me to build one for you? Or are you hoping for a bargain on a used one? I assume you've looked at all the usual places, Metric Mechanic, Korman, TEP.
Hi, I still have this engine it's a good one I thought I had a guy that wanted it but.... With a good ignition and a header this engine made 158 HP at the rear wheels thats over 170 at the crank.
John
2002 or 320I Performance street engine for use with Dual Sidedraft Weber carbs or aggressive F.I. conversion like dual sidedraft throttle bodies.
Slightly lopey idle at approx. 1000-1100 RPM. 9.8:1 compression ratio. 91mm or 92mm big bore for 2100cc + displacement. Aggressive Street Head porting. 294 to 306 camshafts. Race prep on rods and crankshaft. Heavy duty dual valve springs. Mandatory use of Ignition upgrades. Tii Distributor. MSD Ignition package. Header. High flow muffler and pre-silencers. 2.25" exhaust pipe.
