Date: 5-13-08 01:31 From: rx8rotary Subject: Pop out window locking mechanism - how to adjust
The locking nut on both my quarter window locking mechanisms are starting to get where they won't lock the window in place while it is open. Is there a method to repair these or are new ones the solution?
Thanks
BOB
Date: 5-13-08 01:51 From: mike in Beavercreek, OH Subject: If they're the all chrome ones (used prior to approx VIN
2588xxx--late '73), the large screw slot on top of the ball-shaped joint can be ever so slightly tightened to hold the window open.
On the later ones with black plastic knobs, tightening the knob will have the same effect.
In either case, it doesn't take much to go from floppy window to one that won't move...
mike _________________ '69 Nevada sunroof--"Wolfgang"
'73 Sahara sunroof-- "Ludwig"
Date: 5-13-08 02:15 From: rx8rotary Subject: Re: If they're the all chrome ones (used prior to approx VIN
My issue is that when I tighten them they still won't hold the window tight enough to stay open - it is almost as if they have reached their limited before they start doing their locking job
