Date: 5-11-08 08:09
Subject: Re: how many of you actually torque stub axle nuts?
Attached is how Boeing figures you to perform torques, especially with higher than normal limits using some math and torque adapters.
Hope it helps,
Torg _________________ 1976 2002, 2743935, "TIN CUP" (Polaris), near Seattle
426.73 KB |
14 Time(s) |
Date: 5-11-08 11:51
Steve,
Yup, I use a torque wrench, and an extender and calc it. Tried by gut feel one time, and it was tight, but obviously wasn't tight enough, and it got loose and stripped.
Never did it the other way, and overtightened it. But gotta give the BMW engineers credit to figure how tight exactly to make that big F'n nut.
Tom _________________ I'll drive... ;-)
v i s i o n a u t i k s
Date: 5-12-08 02:58
From: c.d.iesel in South West Connecticut - Darien = The Right Coast
Subject: you actually torque stub axle nuts ?
if your nut is fuched, and the threads of the
stub axle compromised, and the splines
were runing loose, and your splines on both the
stub axle and hub are worn - you need all new
parts and start over again - or just redo it after
a few 100 or 1000 mileswith your method.
 _________________ 1976 BMW 2002 #2743711(sorry I sold it 12/25/06)
Date: 5-12-08 06:32
| Terry Sayther (from his website www.terrysaytherauto.com wrote: | | Be sure to retighten the hub-nut as tight as you can after reassembling the drive flange---Really tight. Tighter than that |
Amen. _________________ ClayW
1976 Fjord 2002 Sunroof
Project Blog: http://www.xanga.com/TX02
