Date: 5-1-08 03:17
Subject: Re: What would be the best dive shaft and diff for a m20 200
| mikekoch wrote: | Use an 02 shaft and have the front section sized whatever trans you use. I had a 320i shaft laying around so I used that, but it's more work than it's worth, and probably isn't any stronger. CSB is in a slightly different location.
Mike |
Sorry mate i idnt understand one thing u said there, Do u rekon i should go for the e21 323i diff and e21 drivr shafts?
regards
Date: 5-5-08 06:02
Drive shafts or half shafts? If it is drive shafts, then Mike's answer is perfect. If it is half shafts, then you may want to look at the following links:
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,304652
http://www.bmw2002faq.com/content/view/17/32/
The best diff, as in the easiest, would be a lsd from an e21 323i, if you can find one.
You'll find more under search.
(... also, it may help to post under General Discussion.)
Date: 5-9-08 06:29
| DB wrote: | Drive shafts or half shafts? If it is drive shafts, then Mike's answer is perfect. If it is half shafts, then you may want to look at the following links:
(... also, it may help to post under General Discussion.) |
Cheers for the help mate, i already have a few LSD's at home, an e21 3.45, e30 4.10 and e28 3.46
