Date: 3-18-08 10:11
Subject: New, first project. Help! Where to start?
Okay, bear with me, I am new to this. I have long had an affinity for '02s, even bought a running car with frame issues in college, but with no where to store or work on it, sold it (doh!). I recently came into a free car that appears to be a good starting point for a working, running car. There is naught but light surface rust anywhere, towers are clean, door sills, everything. Car was running and driven 5 years ago, though the tranny was funky. Then, she was vandalized (all lights and glass destroyed) and stored for 4 years. The guy I got it from had it stored in a leaky garage bay. When we pulled it out the brakes were all frozen. Towed it home, hooked up a battery and it started right up. All electricals appear to work. Runs and hold an idle as long as I run it, but white smoke (greater in volume when throttle is depressed) comes from right side of the engine. I can't get it into gear to drive it, either.
I am not a mechanic, but have several manuals and willing accomplices. My question is, where should I start? I am getting glass soon, so it is not exposed to weather.
Any thoughts? Oh, it is a '74 4 speed, yellow.
Thanks!
Date: 3-19-08 05:43
Subject: Re: New, first project. Help! Where to start?
For the brakes, shall I assume that what's on there is likely toast (since they were frozen and I had to hammer on them for a while to free them up enough to tow it) and plan to replace? And, is there a sensible upgrade if I have to replace the brakes anyway?
The headlights, all other lights and all the windows were smashed in the vandalism incident, so they have to be replaced anyway.
The electricals all work, as far as I can tell, heater fan, wiper motor, etc., though I haven't tested the lights (due to their destruction).
What about the white smoke in the engine bay? Sound like cracked head gasket, manifold gasket, a simple hose issue?
I believe the carb is a two-barrel weber, I will look when I haul the car out this spring.
Thanks for the to-do list, I appreciate your help!
Jason
Thanks!!!
