Cris:
What is the total $ for silver wheels with nuts and emblems? I have only driven various '02's, with the exception of an 1800TI, since 1969 - more than a million miles. My experience is that 15x7 wheels with a 25 mm offset will not fit with even 195/50-15 tires on either a stock 2002 nor a tii, even with the lips rolled. 15x7 will fit with 205/50-15 with a 28.5 mm offset and rolled fender lips; 195/50-15 will fit on 15x7 with a 31 mm offset and rolled lips. What is your experience? And how does one further bulge the front fenders to accomodate 25 mm offset? By fit, I mean no rubbing anywhere on downhill hairpins at .4g.
I also have a Zender turbo-flared tii, Chamonix. I have run 15x7, and 16x7 with 205/50 and 225/45 respectively with 0 offset, but 12 mm is really optimal for 15x7 to 17x7.5, and the aforementioned sizes fit; I've even run chains. Longer wheel studs allow either centric-, or not, spacers on wheels like the Rota 25mm's at minimal expense, so long as due care is taken to hub center the spacers and wheels.
I love the period-correct Minilite look and would like a set for each of my flared and non-flared tiis, assuming you concur.
Zwoirle
Zwoirle bedeutet "l'i'l deuce coupe" auf Schwaebisch.
96.82 KB |
76 Time(s) |
96.91 KB |
62 Time(s) |
