Thread Topic: DCOE fule pressure Threaded
Date: 12-21-05 04:51
From: o2obsessed in The Keystone State View user's profile Send e-mail
Subject: DCOE fule pressure
How much fuel pressure should be ran with the dual 40 dcoe's? Should i use some sort of adjustable fpr? Thanks in advance for you help.
Date: 12-21-05 05:00
Subject: 3-3.5 lbs max! (nt)
1967 BMW 2000ti # 1435350
Das Rasende Wohnzimmer!
Date: 12-21-05 05:45
From: jdp530 in Texas View user's profile Send e-mail
Subject: Re: 3-3.5 lbs max! (nt)
Mcmil is right, about 3 to 3.5lbs. I do use an inexpensive fuel pressure regulator on both of my cars, '76 '02 with dual 40s and a '76 530 with triple 40s. I do not use a return line on either car.
Date: 12-21-05 05:54
From: SteveH in Central New Jersey View user's profile
2.5-3.5. I don't notice a difference.
I use a regulator and no return line, which may explain why the pressure ramps up when the engine is shutdown. There seems to be a bunch of different suggested pressures depending on when the information was published, and who wrote it. I remember seeing an "old" "wrong" (around 2 lbs) pressure and a new pressure that was slightly higher.
76 2002 40 DCOEx2 292 Shrick
1984 Mercedes-Benz 300D Turbo Diesel 240,000 miles
Date: 12-21-05 06:19
From: BigDog in Sammamish, WA View user's profile Send e-mail
Subject: I seem to remember 3-3.5 (more)
I think it's as much the volume as the pressure. I run the Carter pump that is reccomended, and it works great!
It's a 4070 pump, and available for about $30 less at Summit Racing.
Here's the TEP link about fuel.
http://www.racetep.com/webfuelspark.html#webfuel
BigDog
'76 2002 Weber DCOE40s
Date: 12-21-05 07:02
From: ridr4lif in East Hampton, NY View user's profile Send e-mail
Subject: Re: I seem to remember 3-3.5 (more)
BigDog
I use this pump and have had no problems with it.
Date: 12-21-05 09:43
Subject: Fool pressure? I run 4 psi
without seat recession problems...
but I run a pair of Holley Blue pumps (not the best choice, admittedly)
with bypass Mallory regulators.
TEP is a bit over the top on the whole fuel pump thing- as long as you have STABLE pressure, our cars don't need a huge amount of volume, even at WOT for long periods
The Carter pumps seem to have identical delivery characteristics to the Holleys- and I'd run a bypass regulator on 'em, just 'cause.
Date: 12-22-05 09:56
From: toddman in Seattle, the sunny part View user's profile Send e-mail
Ditto. I use this pump, it's mounted in my trunk with a fpr. I am told an fpr is unnecessary....
All it takes is money
Date: 12-22-05 12:46
Mounted mine in the front, where the battery used to be, I also run a Filterking filter/regulator, but the reg portion really isn't needed.
BigDog
'76 2002
