| vintage_car wrote: |
any engine shots...I know I'm ruining my own thread, but that is a sweet ride. Do you have the XM commander in front of the shifter? What sort of power issues did you run into adding those extra electronics? Did you bump up the altenator size?
So 15x6 is what I need to look for to have proper clearance with the panasports. Will I need to roll the fender? what tires size is recommended for that? |
Oddly enough, I do have some engine shots!
No XM Commander though. What I have there is three gauges. Amps, Oil Pressure and Water Temp. Below that is a BMW radio with a cassette deck (that doesn't work). Below that is a an EQ then a couple fuses and the Hazard switch.
Next spring, I'm upgrading the radio to a CD/MP3 player, removing the EQ and using that space to hold CD's.
I have a stock alternator and an electric fan mounted in front of the rad. I've have never had any power issues.
Yes, Panasport 15 x 6 ET29 will give you the proper clearance. If you want good rubber, I recommend 195/50/15 Bridgestone S-03's. I raced Formula Fords for 10 years and instructed for a number of racing schools/car clubs and I really like these tires. Great in the dry, very forgiving and absolutely amazing in the rain!
I love leaving people behind on the on/off ramps!
As for rolling up the fender lips, mine were rolled up when I did the body 10 years ago, but I'm not 100% sure it's necessary. Maybe yes, maybe no. I also have tii struts and brakes up front.
The colour's a little off in the engine pics because it was a really bright sunny day.
Hope that helps!
The Toys:
1975 - 2002 - Jade - Daily Driver
1975 Honda CB400F
2005 Toyota Matrix XR - Winter Beater
Remember: RACECAR spelled backwards is RACECAR
469.25 KB |
8 Time(s) |
288.81 KB |
24 Time(s) |
302.22 KB |
20 Time(s) |
290.5 KB |
18 Time(s) |
479.3 KB |
10 Time(s) |
