Thread Topic: Red "L" light came on the morning... Threaded
Date: 12-5-05 11:14
From: RayC911 in San Ramon, CA View user's profile Send e-mail
Subject: Red "L" light came on the morning...
on my way to work. It's the light next to the orange"O" light when you turn the ignition on. (sure most of you guys already knew that). I don't have an owner's manual but is it safe to assume my alternator or something electrical is going out? I drove with my lights on and the 02 started after several stops with no issues. Any ideas before I start testing things out tonight? BTW, it's a 73 02. thanks
Ray
73 Chamonix-S14 powered
Date: 12-5-05 11:24
From: ifayeoh in 87124 View user's profile Send e-mail
Subject: Start with checking the Grounds, battery, alt, engine and
Belt condition, tight?
frank
frank o
1971 2002 sunroof, daily driver, Recaro SE, Turbines, 5 speed
Date: 12-5-05 12:08
Subject: Re: Red "L" light came on the morning...
Check the alt/WP belp tension.
Check the ground wire from the alt to the car body or engine.
Check to see that the three wire connector is fully plugged in at the alt and the V reg.
Date: 12-5-05 12:43
From: mixamson in Portland, OR View user's profile Send e-mail
I'm really glad you asked this because I just got on to ask the same exact question. COOL!
Date: 12-5-05 01:37
From: brad_c-ville_VA in c-ville, VA, USA View user's profile Send e-mail
Subject: yep, loose belts and connections
crapped out alternator mounting bushings could cause a loose belt, but they usually cause the belt to squeal when you rev the engine...usually.
my "L"ectric idiot light came on when i had a loose connection to the + lead...it was holding on by about 2 threads. re-crimped it and it fixed 'er right up.
good luck!
'68 gray 2002 pig-cheeker - '74 verona 2002 - '74 turkis 2002ti(-i) project - '97 Ford Ranger parts hauler - '06 astro black MINI Cooper
Date: 12-5-05 04:51
Subject: Thanks for the input and advice. I'll check everything
tomorrow. Glad to know my "check engine" light works.
Ray
Date: 12-5-05 08:48
From: Clydeg in Little Rock, AR View user's profile
Subject: Re: Thanks for the input and advice. I'll check everything
one of your alternator diodes is probably blown
'73 2002 "Gretta"
'70/75 2002 "Wilhelm" aka "Slick Willie"
'74 widebody with schnitzer flares "Brigette"
'75 parts car
BMW CCA #19280
The difference between Genius and stupidity is that there is a limit to genius - Albert Einstein
Date: 12-6-05 07:39
Subject: One more thing...
The three prong plug on the backside of the alternator--they can corrode, the wires crimped to the terminals can come loose, and the plug itself can work loose from the alternator. It's supposed to be held in place with a wire bail (clip) but this part is often missing. Check that, and the brown ground wire that runs from the alternator body to the engine block. That's the alternator's only ground path due to its rubber mounts.
