Thread Topic: My tranny update; Think I'm going for a manual gearbox Threaded
Date: 10-17-05 07:51
From: Victor_PR in Puerto Rico View user's profile Send e-mail
Subject: My tranny update; Think I'm going for a manual gearbox
Hi everyone;
I managed to get my hands on a 4 spd gear box. As some of you may remember, my automatic transmission went broke. When I bought the car 4 years ago, the PO gave me a 4 spd tranny that he had removed from a '75 or '76. It was working at the time of the removal. Here are a few pictures I took yesterday. I have a few parts that I have from a previous purchase of an old NOS inventory.
I know I will need to get more parts such as:
1) Shifter rod with boot console
2) Brake fluid reservoir
3) Clutch Cylinder (From my inventory, I got these 2 cylinders but I don't know if they are compatible or are from a 1600 - see pictures)
4) Clutch Slave
5) Hydraulic lines for the clutch/slave connections
6) Flywheel (My pressure plate has Sach's PN: 3082-061-232
7) Pedal box with pedal assembly
I'm sure I need more parts so please help me identify them. I have a person who could do the work for me but I want to make sure he has everything at hand (tha conversion will take place in my garage so I don't want to extend the project more than it has to fetching for parts).
TIA
[/img]
Victor
1974 Automatic Sienabraun Metallic
Eibachs/Bilsteins HD/Crane XR700
Weber 32/36 BWA 15" Wheels w/Dunlop FM 901
Hella 500 Fog Lamps
Frigiking AC Recaros/320is Steering Wheel
Date: 10-17-05 08:02
Subject: Re: My tranny update; Think I'm going for a manual gearbox
I dont see the clutch release fork lever (21511202647).
I am not sure, but i think you will need the driveshaft that goes with a 4speed too, the auto box got a 6 bolt guibo if i remember well.
Pat Allen
1974 2002 auto
1997 Pathfinder
Date: 10-17-05 08:03
Subject: Specific Parts with Part Numbers I have at hand.
These are the part numbers of the few things I have at hand for a 4 spd transmission:
1) Output shaft bearing: 23.12.1.205.522
2) Grooved Ball Bearing: 23.12.1.204.198
3) Cylindrical Roller Bearing: 07.11.9.985.720
4) Needle Sleeve Bearing: 11.21.1.276.551
5) Shaft Seal: 11.14.1.255.015
6) Release Bearing: 21.51.1.204.225
7) Clutch Disk: 21.21.1.225.562
8) Pressure Plate: (Sach's P/N: 1861.661.032
9) Transmission: 232.0.139.00 also has 52 225
10) Seal: 23.12.1.284.211
11) Seal: 23.12.1.205.340
I may have a lot or I may have a few; what I don't have is a clue!!
TIA everyone!
Victor
Hella 500 Fog Lamps
Date: 10-17-05 08:07
Subject: Thanks Pat; I do have the drive shaft as well. (nt)
Victor
Hella 500 Fog Lamps
Date: 10-17-05 10:06
Subject: The center console shift surround trim you will need as well
It is different on a manual vs an automatic.
Jeremy
'72 2002Tii - Track Car
